posted by gusto on Aug 07, 2007
I recently had to replace the uv lamp in my unit. Now when I turn on the power the fan comes on for a couple of seconds and the unit shuts off. The front panel never lights up. What do I do?
1 Other User Has The Same Problem
Comment by Controls Eng, posted on Dec 22, 2007
I have the same problem. I was changing the purification plate and the same thing happen. The fuse is good, the power is going thru the air switch to the mother board. Can any suggest the next step.
Solution #1
posted on Feb 05, 2008
I would guess misplaced wire.
Depending on how many and which wires you displaced to accomplish the bulb replacement. I would have to guess that if you did everything correctly and perfectly then the circuit board failed.
My other guess is that if you removed the front panel to circuit board connectors, you may not have reconnected the smaller thin ones on the left in the correct position.
If those check correct and all the other wires are in the correct locations, then there is a repair outfit located through the internet that seems reasonable for approaching for a more involved repair job. The one I looked up had rebuilds available, so you might be able to get a replacement for a better price with your old one exchanged.
If you go this route, just do a web search for EQ air purifier parts/repair.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Ecoquest Fresh Air Air Purifier
Email this problem
Email this problem
Can you Help with these Air Purifiers problems?
fresh air won't come on
I have an older Fresh Air (2004... Answer This...
man shook my air filter to try...
It isn't broken but doesn't... Answer This...
Repair Service
Find Air Purifier Repairman Near You:
