Question about Garden
How to remove gas tank john deere 3020
Process to remove gas tank on john deere 3020
SOURCE: john deer
Hi if you look on the side of the oil pan there should be a square plate with 4 bolts the oil filter is behind it its a paper one Fram C139PL and a new gasket comes with the filter. I hope this helps. M.L
Posted on May 05, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
BAMOUT
  • 2478 Answers
SOURCE: I need to know the wiring process for a john deere 3020 diesel starter
Posted on Aug 13, 2012
BAMOUT
  • 2478 Answers
SOURCE: remove spindle john deere 3020 tractor
Remove bolts or clamp on top of spindle. Next remove steering tie
rod. It should slide out.
Posted on Sep 27, 2012
Torque specs for the intake and exhaust manifold bolts 3020 gas
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
1964 john deere 3020 WORKSHOP SERVICE REPAIR MANUAL
Jan 08, 2016 | John Deere 3020 Gas & Diesel Tractor...
How do I change the fuel filter on my 3020 John Deere diesel tractor
Leaving the fuel valve on the tank in the on position will allow fuel to run through the line & keep the air purged during removal. On the other side between the pump & the filter, having the new filter topped off & speedily installed will lessen the chance of air entering the line. Once the filter is installed, open the bleed screw at the top of the filter. Just my redneck way.
Oct 05, 2014 | John Deere Ar50041 Diesel Fuel Filter 3020...
Tractor wont start
is gas getting to carb yet first takes some priming time
Sep 04, 2014 | John Deere 3020 Gas & Diesel Tractor...
Ran out gas 3020 now will not start
try squriting some stating fluid in it the carb it should start if does look for water are dirty gas replace it with clean gas fresh gas dont use old gas chang fuel filter changs hydrostatand filter and oil do a service on it use a fuel additve called`sea foam in only one that i no that works follow instruction on bottle how to use see if that wont get you going
Sep 03, 2014 | John Deere Step 2510 2520 3010 3020 4000...
Remove spindle john deere 3020 tractor
Sep 26, 2012 | John Deere 3020 Gas & Diesel Tractor...
Deisel fuel finished and it wont start now
Sounds like it needs the fuel pump primed. Try bleeding it as close the motor as you can.
Aug 07, 2012 | John Deere 3020 Gas & Diesel Tractor...
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
Garden Logo
197 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
