Question about Acer Aspire 3680-2022 PC Notebook
Screen brightness screen is not as bright as usual
  • Acer Master
  • 7,627 Answers
Have you done ANY updates? Are you on Battery power? Open the control Panel, select Power Options(Vista) Display(XP), do you have XP or Vista?, XP:http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_overview_w.mspx?mfr=true Vista, Power Options, http://msdn.microsoft.com/en-us/library/ms700612(v=vs.85).aspx If on battery your laptop will din the display to conserve battery power. It could be the components are going bad, age. Have you cleaned the fan, vents, heatsink recently?
Posted on Apr 29, 2013
My lenovo ideapad z500 monitor
type in model # on lenovo.com download the manual for the monitor usually just push button on monitor Menu move to brightness adjust to higher brightness
Jan 01, 2014 | Lenovo IdeaPad Computers & Internet
Brighten lcd screen
OK, you are part right. The Fn key on most laptops is written in BLUE. This corresponds to the BLUE legends on various keys on the keyboard. MOST laptops have a pair of generic symbols for the screen brightness up and down . The brightness UP is a blue square (rectangle) with a large asterisk inside. The brightness DOWN is the same except it has a small asterisk inside. You will usually find these two keys as a secondary function of a function key.
Example: On my ACER netbook Fn+F6 = brightness UP and Fn+F5 = brightness DOWN
Nov 13, 2013 | Acer TravelMate Computers & Internet
Brightness screen fn
Many computer users spend long hours online every day and don\'t realize that looking at a bright laptop screen can be hard for the eyes. If you spend a lot of time in front of a laptop screen, consider reducing the brightness of the screen at the earliest opportunity. There\'s a quick and easy way to perform this task so you can save your eyes as well as your battery power.
Press and hold the "Fn" key on the laptop keyboard. T his key is usually located at the top right or bottom left of the keyboard. Press the "Up Arrow" and "Down Arrow" keys, which are usually located in the lower right of the keyboard, to increase or reduce the brightness of your laptop screen. Adjust the level so that you can gaze comfortably at the screen without any glare. Disconnect the battery charger from your laptop and repeat the above procedure. On some laptops, the screen brightness varies considerably, depending on whether or not the device is charged.
Jan 31, 2013 | Dell Inspiron Computers & Internet
Hp probook 4520s charging time more brightly .battary off time darknessly
Laptop screen is normally brighter when it is connected to the charge adapter. When the laptop is running on the battery it is usually a little dimmer to save battery power, you can adjust the screen brightness even on battery power. To adjust the brightness hold down the Fn key and press one of the function button keys it maybe the F7 or F8 key it will have a symbol on the key to indicate the screen brightness.
Dec 18, 2012 | HEWLETT-PACKARD ProBook 4520s
How do I adjust the brightness on my laptop? Its a Compaq Presario V2140US
1. Press down the Fn key at the lower left end of your Compaq Presario keyboard. Keep the button held down and tap the F7 key to decrease the screen brightness by one step.
2. Tap the F7 key again with the Fn key still depressed to further decrease the brightness by one step. Continue hitting the F7 key until you reach the minimum LCD screen brightness.
3. Hold down the Fn key and tap the F8 key to increase the Presario's LCD screen brightness by one step. Keep pressing the F8 key until you reach the maximum brightness for your screen
Mar 01, 2011 | Microsoft Compaq Presario C501nr Notebook
How do I adjust the brightness? It's too much?
By following these steps u can adjust the brightness
Step 1
Press "Menu" on your LCD's display panel (usually below the screen). Various display options will be shown on the screen.
Step 2
Select brightness from the options. This is usually indicated by a sun. Use the "+" and "-" buttons on your display panel to increase or decrease brightness.
Step 3
Select contrast from the options. This is usually indicated by an oval half black and half white. Use the "+" and "-" buttons on your display panel to increase or decrease contrast.
Thank you
Mar 28, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
MY Laptop Screen Is Dim It Will Not Show Bright
When you say that your laptop "screen is dim", do you mean that there is no light coming from your screen, but you can see images on it? or do you mean that there is light coming from the screen, just a very little amount?
If you can images, but NO light is coming from the screen, then the LCD backlight is dead, and it needs to be replaced.
If there is light coming from the screen, but it's very dim, then you'll need to find the screen brightness adjustment keys on your laptop. This is usually two keys. The first one is normally in the lower left corner of your laptop and should be a different color - like blue or purple, and will be labeled something like "Fn". The second key is normally in the function key row (F1, F2, F3, etc...) and has a symbol on it that looks like a sun or burst of light with an arrow. There's usually one for "brightness UP" and one for "brightness DOWN". Hold down the Fn key, and then press the "Brightness UP" key a few times to see if the screen brightens up. Good luck.
Jan 14, 2010 | HP Pavilion dv1000 Notebook
The screen is extremely dark on the e620, how do you adjust the screen brightness
Look for the symbol on the keyboard, usually on f4 and f5 that looks like a sun, it will be stamped usually in a light blue or purple color. Hold down the fn key which is to the left of your keyboard and use the F5 key or brightness symbol with arrow up to brighten the screen. If the screen still does not get very bright, it may be an inverter or and LCD Issue.
Dec 11, 2009 | E-Machines M2350 Notebook
How can I lower the brightness of my screen in my Dell 1525 lapto
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Jul 28, 2009 | Dell Inspiron 1525 Laptop
Dull picture on laptop but cursor is still bright
The screen brightness is automatically adjusted by your laptop's Power Management configuration in the Control Panel. Depending on your laptop's brand you might not only have the Windows power management, but also a proprietary power management application within the control panel or in your Start Menu programs usually listed under your computer's brand name. For example a program folder called "Toshiba" under Programs for a Toshiba laptop. Anyway, I would start there. Usually you can set up the screen brightness according to whether or your computer is plugged in or working on battery. Good luck! :)
May 22, 2009 | Toshiba Satellite A105-S4004 Notebook
Acer Aspire 3680-2022 PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
