Question about Konica Minolta Bizhub 501 Copier
Bizhub 501 error codes c3801 - Konica Minolta Bizhub 501 Copier
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Maybe the power it's not correct.Try to reset hold utility key and power on hold the utility and on screen will be show the ikon trouble reset push it and will show ok power of and on again
Posted on Feb 13, 2016
HOW DO I CLEAR C3806 ERROR CODE ON BIZHUB 501? PLEASE FORWARD ALL DIAGNOSIS CODE
Fusing main temperature low sensing.
clean TH1-Thermistor.
Power ON machine by pressing Utility Button.
and hold for 15 to 20 seconds.
Touch TROUBLERESET once appear.
now restart machine from main Power which is under Toner Door
Dec 21, 2016 | Konica Minolta Bizhub 501 Copier
Code irror 2702
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Apr 26, 2016 | Konica Minolta BizHub 360 361 420 421 500...
I have one photocopier bizhub 501 and have error code 2801/03..Can you help me? thnx
Take the toner bottle out. Then you will need to remove several cover to gain access to the sensor way in the back of the where the toner bottle goes and clean that sensor. might even need replacing.
Aug 25, 2015 | Konica Minolta Bizhub 501 Copier
HOW C3801 BIZHUB 421
Thermisters / Heat Sensors abnormality. Replace the thermisters, in order to get rid of this problem permanently.
May 26, 2014 | Konica Minolta bizhub C351 All-In-One...
C0501
The 501 code is not for bizhub 350 is for dialta 250/350/2510 and refer to fusing unit error.
Dec 16, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica bizhub 501 take code c2806
actually code c28xx have 7 variant. for example, c2801, c2802, c2803 (error 3,4,5,6) and c2804. if follow the code code c28xx is TCR output abnormality.
ok, first you clean T/S block, do servicing and cleaning all parts.
second, if still same, do toner auto supply.
third, trouble reset. off your machine first, press and hold utility/counter and on machine, until trouble reset appear. press it and off/on again. ^^,
Oct 05, 2013 | Konica Minolta Bizhub 501 Copier
Bizhub500
replace center sensor or use reset in the sofware mode
Apr 24, 2013 | Konica Minolta Bizhub 500...
My konica minolita bizhub 501 is showing the error code C3501. How do I fix this?
if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
ENSURE YOU WAIT 10 SECONDS
1.
Turn OFF the main power switch. (Located inside machine) Leave control power switch in the on position.)
2.Turn main power switch ON while pressing the Utility/Counter key.
3.Touch [Trouble Reset].
4.Check to make sure that [OK] is displayed and the it has been reset.
5.After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Oct 12, 2012 | Konica Minolta Bizhub 501 Copier
Error code C-11C0. Can anybody help?
C11C0 Punch Motor malfunction See FS-501, FS-603 or FS-514 Service Manual.
Feb 25, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub 501 Copier Logo
656 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
