Question about Electrolux Washing Machines
EWX14450 washer dryer. Drain works fine. Why is it overflowing?
Recently stopped working properly. On a normal wash cycle the drum fills but continues to fill past the normal point until it flows over the detergent drawer. Strangely though when the machine is on dryer mode it cycles for about 10-15 minutes and then beeps showing E10 error code which according the manual is a blocked water inlet hose!?
  • Robert Astbury
    Robert Astbury Jun 27, 2015
    I have this very same problem. tried cleaning filter. still not working
  • Robert Astbury
    Found the problem. after taking the lid off. i took the pressure switch off the hose. blew on the pressure switch when filling and you can hear the 3 clicks. the machine resumed onto next phase. i blew down the hose and this was clear and bubbling into machine. but then i discovered half way down the hose - it was damaged and had a hole. presumably from the drum rubbing on the hose over many years. now just need too replace this and it should work fine.
Found the problem with mine that had identical symptoms... after taking the lid off. i took the pressure switch off the hose. blew on the pressure switch when filling and you can hear the 3 clicks. the machine resumed onto next phase. i blew down the hose and this was clear and bubbling into machine. but then i discovered half way down the hose - it was damaged and had a hole. presumably from the drum rubbing on the hose over many years. now just need too replace this and it should work fine.
Posted on Jun 27, 2015
  • Robert Astbury
    previous checks i did was to check the filter was clear first, and use a wooden spoon to try and turn pump inside filter hole too see if there was resistance, also removed drain pipe into bucket to check flow rate was high. drain stage worked fine. Drying phase trickled water in but would not drain, (water during this phase is okay, its used for the condensing process) but i also suspected the filling inlet valve. but this stops filling as soon as you power off the washing machine, so it couldn't be this. for me that left me with only the pressure switch and hose left at fault...
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
aborcass
  • 2651 Answers
SOURCE: kenmore elite h4 washer fh code
F/H is a no water fault code, so i would recheck your incoming water supply, or look to a problem with the inlet water valve.. if your using stainless steel hoses, form the manufacture lableld FLOOD SAFE, these maybe your issue as well they have a buitl in water shut off, htat may be failing preventing water from entering
Posted on Nov 30, 2008
SOURCE: LG all in one washer dryer fills with water on the drying cycle
I had the same problem with my machine this week and I discovered an auxillary drain that was clogged with lint. If you lift the inner lip on the bottom of the door gasket you will see a small hole. This hole is actually connected to a skinny tube that drains to the main water pump. Mine was clogged with lint and the water that had accumulated there was draining back into the drum and soaking the clothes again. I cleaned it out and blew air through it and now the machine works like new again. I hope this helps.
Posted on Feb 06, 2010
SOURCE: my frigidaire stackable washer/dryer will not drain water or do anything past filling up
my washer fills up with water but will not drain
Posted on Feb 13, 2011
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Washer will not stop!
call a service technician to get a proper diagnosis and quote then decide to fix or junk
Jun 10, 2017 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Estate Washer will not stop filling.
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Apr 16, 2017 | Estate ETW4400VQ Top Load Washer
Ge wbsr washer overflows...
Could it be ...this happens only when it is overloaded or the load is out of balance. Please clarify.
If this is not the case .. the water level hose running from the outside tank to the water level switch is likely not making a good seal (otherwise the water level switch itself is bad). Sometimes with age the hose forms a crack in it near or at the end where it connects. This could happen at either end of the hose. Also if you have removed the control panel recently (for any reason) you may have (not knowingly) pulled the water level hose loose from the water level switch. Just slide the hose back onto the tube of the switch before putting the control panel back in place and all will be fine after the first filling of the tub (it may take one filling cycle to build the needed vacuum back up in the hose). Unless of course in the process you have broken the tube off the switch where the hose goes on. In this case replace the switch.
Jun 05, 2017 | GE WBSR3140DW Top Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
My Roper top loading washing won't stop filling.
It's not necessarily the angle of your drain hose. When it drains as you fill it, it's called a siphon condition. Pull the excess hose out of the stand pipe (drain). Only about 6" should remain inside the pipe. Tie it down with a plastic tie to one of your fill hoses to prevent water pressure from pushing it back out. This should solve your problem.
Nov 10, 2007 | Roper RAB2121KW Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
121 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
