Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Knocking idle Knocking at Idle, but seems to go away when throttled up.
  • D.J. Apr 29, 2013
    Regular Oil Changes and has about 450 Hours. Seems to have some Oil Seepage coming from under oil filter (which has been changed, so not filter itself) or from under valve cover next to Filter. Not sure that loose valves would cause this.. or could it?? Any help would be appreciated!
  • D.J. May 01, 2013
    Tension Idler Pulley Bearing went out.
    Removed Deck: Still Knocked at Idle and went away at half to full throttle.
    Removed Drive Belt: Knocking went away and ran smooth as "a hot knife thru warm butter!"
    Removed Tension Pulley: Spun by hand and did NOT spin smoothly. Bearing failure!
    Thanks for looking at least... :-)
    New Friend:
  • 171 Answers
Piston too loose in the bore?
Posted on Jun 23, 2013
When my 2001 indy 500 idles i have a knock
idle knocks indicate worn pistons or worn gudgeon ( wrist pin) bushes
check the ignition timing as it may be too far advanced for idle causing piston slap
Sep 09, 2017 | Polaris ATV
1999 3.0 ford ranger knocking at idle only
It sounds like a valve or valve lifter issue. First check and make sure the oil livel is where it needs to be. Then, I would let it idle for a few minutes and see if the knock goes away when it warms up a little (still idling). If not, its a bit more in the advanced stages of a valve or valve lifter going bad. Either way, I would change the oil with some high quality synthetic oil and get a filter with a non drainback valve (k&n or Mobil 1 has them for sure). Those attempt to keep the oil in the top half of the motor when you shut it off. I would always let your car run for a minute (longer in winter) before you drive it to get the oil pumped up and circulating.
Aug 11, 2013 | Ford Cars & Trucks
Knocking noise on idle
Most likely the rocker shaft end float that needs to be adjusted.
Apr 16, 2012 | BMW R 1200 GS Adventure Motorcycles
1993 mercury villager check engine on with code 32 and 34. repair manual says the code 32 doesn't bring the check engine light on but the 34 does. code 34 says problem with the egr valve solenoid or...
After awhile these idle screws don't have a lot of effect, the throttle body & injectors are also probably dirty. The 1.5 turns out from a soft seat is a starting point. Go another 1 to 1.5 turns out to find the sweet spot. Pour a can of Seafoam in with about 1/2 tank of gasoline. That will help clean the injectors & combustion chambers. Clean the throttle body with throttle body cleaner, make sure there is no carbon around the edges of the butterfly and where it seats.
The knocking on starts is most likely from worn bearings. It will knock until oil pressure builds up & is circulating through the journals. I hope this helps.
Sep 24, 2011 | 1993 Mercury Villager
1997 galant, There seems to be a knocking sound coning from right side of engine in the section next to oil cap, knocking seems to go away while accelerating or driving but sounds loud and terrible at...
The only thing in that area that can really cause a knocking sound are the valves and tappets. Check the valve clearances or the lifters for a defect.
Feb 02, 2011 | 1997 Mitsubishi Galant
Ok. Last night my car started making a knocking noise. Its not loud and only happens when im in idle. Also it seems to come from the bottom of the engine. Help?
if it gets louder and faster as the engine speed increases then a piston is knocking...if it is just at idle like you said then it could be a bad oil pump if oil light is on at idle or it could be the connecting rod knocking on the crankshaft because it is loose.
Oct 23, 2010 | 1999 Pontiac Sunfire
Knocking when engine gets hot and car stopped
Sounds af if you may have a transmission issue. I would take it to dealer to have it checked. Noises can be hard to track down even if you are standing next to a vehicle unless you have proper training in vehicle drivability
Mar 14, 2010 | 2003 Chevrolet Blazer
The fan clutch can make a knocking noise when it tries to engage. At idle it will have a rhythm to it when it tries to engage. You will have an over heating condition and the air conditioning may not work properly.
The fix is to replace the fan clutch and reprogram the engine control module.
Mar 14, 2010 | 2003 Chevrolet TrailBlazer
1996 chevy s10 4.3 vortex lifters knocking at start up but goes away after 10 minutes idling. changed oil and filter oil pump reads 58-60psi at idle and seems to be working.
High milage? Try engine cleaner, run for couple hundred miles and then use an additive like Restore. If it's just dirt this may help. Make sure you are using the correct viscosity oil for winter temps. If it's from wear only parts replacement will fix it.
Feb 07, 2010 | 1996 GMC Jimmy
Knocking noise at idle
This is AC compressor rattle, don't worry about it unless it is really loud, in that case replace the compressor.
Aug 23, 2008 | 2003 Chevrolet Trailblazer Ext
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
182 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
