This morning I woke up and my freezer had defreezed. It ruined all my food! My refrigerator also seems to be refrigerating less, all the food in it is just barely cold. All the rest seems perfect, the noise of it's functioning seems the same, the lights are the same, everything seems the same.... I kept the door open for some time since I started to clean it up and it seemed all the time that everything was fine (it even made that noise that ir usually does when you are open for too long and it has to work harder) other than it not cooling enough and not freezing in the freezer.
Check for a plugged coil under the refrigerator. Remove the kick plate and look with a flashlight and see if you can detect anything blocking the air flow from under the box to the back. And be sure if you pull off the cardboard back you put it back on because this has to be in place for the air to flow properly.
If you have frost in the freezer area then you have a defrost problem and have to persue another corce of action get back to me and let me know how and what you find.
If this helps you please rate me as high as you can and thank you for using fix ya.
I don't know what a fan motor on the compressor is.... ????
All the noises are fine...
i have the same exact problem!!!!!!!!!!!
This is creepy because this just happened to me this morning as well.
Remove the back cover on the rear of the refrigerator at the bottom.
The compressor is there. A fan motor is there.
Look to see if the fan motor is running.
Check the fan motor on the compressor, is it running?
