Question about Zoeller M53 Mighty Mate Iron Body, Poly Base Automatic Sump Pump 1/3 HP
What is a check valve on sewer sub pump
Hums but wont pump
  • Amanda Drew
    Amanda Drew Aug 01, 2017
    That's weird that it will hum, but your sewer pump won't actually pump. Have you tried having a professional look at it? Sometimes the problem is really hard for a layperson like ourselves to find, but someone who fixes sewer pumps for a living would be able to find easily. I hope you get this fixed soon.http://www.forrestsewerpump.com
  • Zoeller Master
  • 5,245 Answers
Copy following link:
http://waterheatertimer.org/Repair-water-heater-valve.html#check
Add a comment and describe what you are connecting for more assistance.
Posted on Apr 30, 2013
Kenmore elite front loading washer wont drain keeps having code OE
This question shows me that you have a clog before, in, or after the pump. you would have to check the hose that comes from tub, the pump filter area, the pump impeller area, and the hose that goes from pump out to the sewer. First check your filter for any Clogs. GOOD LUCK FRIEND.
Oct 16, 2014 | Kenmore Washing Machines
Our sewer pump loses prime, when we manually re-prime it will pump but constantly loses prime.
pumps that continually loose prime 4 sure have an air leakage problem two places that most pumps can leak air into them are (1) input shaft seal
(2) check valve
the check valve is by far the easier of the two to replace id start with that one first some waste water pumps have two check valves on them one on suction line and one on discharge line (if over 10 feet high)
Jul 31, 2011 | Monarch Pumps BE-S75 Wastewater Pump...
It makes a humming sound but does not pump water. the pump gets very hot there is no debre in the outflow
The motor is binding that's the humming noise. Check to see what **** the thing sucked up. Then try to clean it out. I dont know what happened
Dec 25, 2010 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
Ejector pumps started to go off frequently
The ejector pumps probably pump to the same sewer pipe you had rooted. Rooting can do damage. Trees can break into your sewer pipe, jam them up with roots, and let ground water in. The ground water may be following your sewer pipes on the outside back to your house. It costs a lot, but you can have your pipes examined with a tv camera, the rooter people can do that. Make sure your ejectors have check valves, and they are working right. It's easy for something to get stuck in the check, and then water will come back.
May 01, 2009 | Zoeller E282 Nonautomatic Waste-Mate
How to Install plumbing in the basement?
A sewer ejector pump is the answer. The waster line is run into the sump basin, pumped through a checkvalve into  the sewer line that grades with gravity.  A vent pipe needs to be run also, (you can't pump out without replacing the air, it's like trying to suck air out of a bottle) If you add a high water alarm, which is a good idea. It is run off of a separate electrical breaker (insurance) to let you know if the pump isn't working before it's flood time.  The check valve makes sure, that what you pump out, stays out. Otherwise the pump will keep cycling.
Aug 27, 2008 | West Brass WestBrass Faucet Master Large...
Washing machine wont fill
the humming noise is usually the inlet valve energised but no water there to come in. i appreciate you have checked. the other possibility is that the appliance has not pumped out completely and the noise you hear is the drain pump energised but stuck due to perhaps a foreign object in it. fault is unlikely to be inlet valve
Apr 01, 2007 | Maytag Atlantis MAV8551 Top Load Washer
Zoeller M53 Mighty Mate Iron Body, Poly Base Automatic Sump Pump 1/3 HP Logo
296 people viewed this question
Top Zoeller Electrical Supplies Experts
Fred Sops
TEKUSER
TEKUSER
Are you a Zoeller Electrical Supply Expert? Answer questions, earn points and help others
