Question about Campbell Hausfeld Powerpal Air Compressor Mt31000s
Psi knob label
Lost theround label that fits no top of the psi indicator selection knob, can you tell me the direction to turn for adjusting the knob, which way to increase ,decrease. and what is the half way point psi setting?
2 Suggested Answers
  • 1388 Answers
SOURCE: high/low pressure spring settings
Generally, the pressure switch is not adjusted more than once or twice in the life of the compressor since the discharge pressure can be adjusted with pressure regulator. However the life of the compressor can be increased if lower pressure settings are maintained. Your pressure switch was set at the factory to a setting of about 120 - 150. If your cutout pressure is higher than 150 surely lower.
STEP 1: Turn Main Calibration Screw ( center screw with large spring) clockwise to increase pressure and turn counter-clockwise to decrease pressure.
STEP 2: Turn Differential Pressure Screw (small spring) clockwise to decrease cut-in pressure and
turn counter-clockwise to increase cut-in pressure.
Differential Pressure is defined as the difference between cut-out and cut-in pressure. There should be about 7 to 12 psi difference between cut-out and cut-in.
In our shop we rarely adjust more than a couple of turns because these switches are sensitive.
Good Luck and please post again if you have other concerns about your compressor.
Posted on Jan 21, 2009
Maruti/ertiga how to set clock.there is no any botton to set the clock
How to set Clock When the ignition switch is in the "ON" position, the display (D) shows the time. 2) To change the hour indication, turn the indicator selector knob (2) left or right repeatedly when the hour indication blinks. To change the hour indication quickly, turn and hold the indicator selector knob (2). To set the hour indi- cation, push the indicator selector knob (2) and the minute indication will blink. 3) To change the minute indication, turn the indicator selector knob (2) left or right repeatedly when the minute indication blinks. To change the minute indication quickly, turn and hold the indicator selector knob (2). To set the minute indication, push the indicator selector knob (2). To change the time indication: 1) Push the trip meter selector knob (1) and the indicator selector knob (2) together. w WARNING If you attempt to adjust the display while driving, you could lose control of the vehicle. Do not attempt to adjust the display while driving.
Hope this helps.
Bob
Feb 08, 2015 | Cars & Trucks
Can I get 80 psi with dials set at 40 psi
this compressor should be able to fill your tires to 80 psi. Look for a pressure switch and adjust it so the motor shuts off at a higher pressure. Do not exceed 100 psi.
Sep 08, 2014 | Air Tools & Compressors
I have a 1992 Toyota Camry XLE and I have lost the knob to select Hot/Cold and the knob to turn the air flow up and down.
No, your either going to have to get this from a salvage yard or you can check ebay to see if you can find it.
Nov 26, 2013 | 1996 Toyota Camry
How do you adjust pressure foot tension
you probably can't adjust the pressure on the foot, most models it is preset with no ability to adjust the pressure. Take a look at the top of the machine, left side above the needle area. If your machine has adjustable foot pressure, there will be a thumb screw of some sort on the top of the machine in this area, possible with a + and - symbol to indicate which way to turn to adjust the pressure.
I have owned Elnas, Janomes and Singers and only one of them had adjusted foot pressure.
Nov 02, 2012 | New Home HF-2022
Brand new compressor...air builds in tank but turning the regulator result in no change in the regulated pressure. Tried turning the regulator to make sure it moves freely, and it seems to, but still no...
The regulator has a very strong spring inside causing knob to get harder to turn as you increase the pressure (increase clockwise). If the knob is easy to turn most likely stripped inside. If knob gets tight as you turn then plunger at rear of regulator is stuck. On the back side of the manafold directly opposite the adjustment knob is a small nut housing a plunger. Let out all the air from the tank and remove the nut. Seperate the nut and plunger, lube and re-install. If the regulator knob is stripped you will need to replace the manafold or as a temp fix remove the safety valve (let out air from tank first) and install a tee fitting. On one port of the tee reinstall the safety valve and on second port install quick fitting for full tank pressure (or install aftermarket pressure regulator ).
Oct 28, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Have lost the control turn knobs for the ignition and heat settings
Gas control knobs can be very specific to the patio heater. Best to go for a universal or adjustable control knob, these have a grub screw that can be tighten to get a good fit, found this specialist patio heater company very helpful.
Oct 01, 2010 | Endless Summer 233000 Open Flame Patio...
How do you set the clock on sony xplod 100db+?
The clock uses a 12-hour digital indication...... Press and hold the select button...... The setup display appears...... Press the select button repeatedly until “CLOCK-ADJ” appears...... Press (DSPL...... The hour indication flashes...... Rotate the volume control dial to set the hour and minute...... To move the digital indication, press (DSPL...... Press the select button...... The setup is complete and the clock starts......
Jan 28, 2010 | Car Audio & Video
Picture out of foucs
HIGH VOLTAGE WARNING - open the tv and on the flyback Xformer, there should be a knob that is labeled FOCUS try adjusting it. the flyback has the red wire on top that goes directly to the the top of the picture tube.
Jan 11, 2010 | Televison & Video
Campbell Hausfeld Powerpal Air Compressor Mt31000s Logo
41 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
