Question about Apple iPod nano
Ipod nano, white and silver, flashing the apple sign
I have bought a 2nd hand ipod nano, took it home, connected it to my computer to charge it, donwloaded itunes 7.something, now my computer or itunes dosent list the ipod, and it is flashing the apple sign on and off, can you help!!!
    Problem Solver:
  • 14 Answers
Also try updating itunes
Posted on Aug 19, 2007
I had the same problem and I just let it alone, plugged into the computer (even though it had plenty of battery) for about 10-20 minutes and it came back! I hope this helps you :)
Posted on Aug 17, 2007
SOURCE:
My ipod nano wont charge and wont turn on.
Sounds like a bad battery. You can get replacement batteries here http://www.ifixit.com/iPod-Parts/iPod-Nano
-=/ Daft Tech /=-
Oct 21, 2009 | Apple iPod shuffle Second Gen. Silver (1...
2nd Gen IPOD nano dead batt.,not recogn.by computer or itunes
can you restore to factory settings?
it may need new battery...even if battery is dead it will still display apple sign but wont sync or charge.
Jul 31, 2009 | Apple iPod nano 2nd Generation MP3 Player
My ipod nano blue 4 gb 2nd generation
try giving it a firmware upgrade
dowload it from ur product suppoert area page
Aug 19, 2008 | Apple iPod nano
Ipod nano(2nd gene)
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Feb 07, 2008 | Apple iPod nano
Ipod nano 3rd generation wont connect with windows xp
You can only sync an ipod with itunes software, it doesn't come with the ipod though.
Go here:
http://www.apple.com/itunes/
On the right hand side it says itunes 7 Download now. That's the software you need to use with an ipod.
Dec 25, 2007 | Apple iPod nano
IPOD NANO WHITE WILL NOT CHARGE AGAIN ON USB
i think u should ask the person u got this i-pod from
Ipod nano blinks
I bought an Ipod shuffle 2nd generation yesterday, it charged all night and orange light was still blinking. Tried listening to songs and sometimes it would play but most times wouldn't. Took it back for exchange and same problem. Then I realized the problem is not with the USB plug or computer reoconizing ipod but in the docking itself. I applied pressure on the top side of docked Ipod and bottom of docking station and the computer recognized the Ipod. Release pressure and lose connection. The problem is that the docking station and earbuds do not connect with ipod and the fixes provided by apple doesn't address or fix this problem.
Nov 21, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Battery
http://www.ipodjuice.com/?gclid=CKWNzPufs48CFSasGgodp1dqSg
The battery is flat, replace it for less than $30. Easy if youre good with your hands, if not- go to your nearest Apple store.
Oct 29, 2007 | Apple iPod nano
My mini ipod freezing, showing charger sign i could not turn it to menu
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 14, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod nano Logo
61 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Parshiv Luthra
Marvin
Marvin
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
