Question about Lennox iComfort Wi-Fi
Lennox Icomfort Thermostat
I cannot get the thermostat to send registration data to the Lennox server. Ive replaced the thermostat, set up a new network just for the router, talked to Lennox tech, checked security, network type, connection strength. It seems to connect to the router, but not to the Lennox server. I use comcast for my iso. Any suggestions? Local dealer seems to have run out of options. Thanks
My thermostat showing on screen 76F when really room temperature is 70F and I HAVE MEASURED PROPER room sensor resistance OHMS to real room temperature. Why thermostat showing higher temperature and n
Where is the thermostat in relation to the return? Is there air flow or is the air stagnant in the area of the thermostat. Have you placed a thermometer in varios locations where the thermostat is located? Try these locations and see if the thermostat needs to be placed in a location better able to reflect room temperature. Also how long have you lived in the house? If it is a newer home I suggest that you contact the builder or the air conditioner/heater installer to see if they have a schematic of the placement of the thermostats.
Nov 25, 2014 | Honeywell TH8110U1003 VisionPRO 1H/1C...
Overheating
After replacing or refurnish engines head is recommended to replace water pump and inspect thermostat, radiator, and cooling fan. Most of the time engines overheat is because there is not enough water circulation thru the head due to malfunctioning water pump, radiator, thermostat and or radiator's cooling fan. By just fixing the damaged head you may not be solving the problem that originally burned your head gasket.
Apr 03, 2014 | Spectre 2001 Audi A3 - 1.8L 4-cyl. engine...
In house temp is high and furnace stll goes on
Might be dust in the thermostat. Filters might be dirty. I would call a service man before the house burns down!
Apr 01, 2014 | Honeywell Digital Round Single Stage...
New a/c - furnace installed, no instruction manual, it is 23 degrees outside, and I have no idea how to turn on heat instead of a/c. Need thermostat instructions.
Usually just put the thermostat fan on auto, the a/c heat switch to heat and set the temperature where you want it. If it's a gas furnace, you will need to light the pilot. Usually instructions are on the furnace door, maybe inside furnace door.
Dec 05, 2013 | Air Purifiers
Where is the thermostat?
a thermostat is always located on top hose from radiator.. just follow ur hose from radiator to engine block when the hose stops then u found it i have not seen a thermostat been any where else, as i been working on cars 9 years ...
Sep 29, 2012 | EBC Brakes 2000 Chrysler Concorde - 3.2L...
I need operating manuals for White/Rodgers
Please check the model number of the EAC?? Once you have that model number handy you can call this number 18002842925 they send you a softcopy of the manual to your email.
May 09, 2010 | White Rodgers UVP06207 Air Purifier
I replaced a Lennox DSL-450LX heat pump thermostat with a Honeywell RTH3100C. Everything works except the gas does not ignite when set to emergency heat. The Lennox was wired as follows: W = white wire Y1...
Hi, If indeed you do have a heat pump, there wouldn't be any gas involved as a heat pump runs on freon with a reversing valve and heat strips for aux and emerg. heat. For gas electric operation thermostat terminals are rc to rh with factory jumper. Red wire to either.W to W for Heat, Y to Y for cooling G to G for Fan. If you have a blue, you wont need it unless this is a commercial stat useing a common for the Led lights on the stat. The unit will get its 24volts through R terminal in combination with y,w,and,g. Cant be a heat-pump if you have a gas furnace.Wrong t-stat. You need a gas /elect stat. And on a 24volt programmable t-stat, the batterys are used for the program only.If the batterys die, than you will loose the program on most residential stats. On commercial stats with the common in play, when batters die the stat defaults back to the factory settings.If you had a Lennox heat-pump stat on a gas/elect unit, you need to change it. Someone was using what they had on hand. Let me know if this has helped you.I will be here if you need me. Sincerely,
Shastalaker7
Nov 17, 2009 | Air Purifiers
Lennox iComfort Wi-Fi Logo
97 people viewed this question
Top Lennox Air Purifiers Experts
Are you a Lennox Air Purifier Expert? Answer questions, earn points and help others
