Encoder strip came out of my canon mx 320 printer. I don't know where it's suppose to go. The strip is not damage at all. Please help! My mom will kill me if she finds out. Thank you!!!
5 Suggested Answers
aomcopier
  • 22 Answers
SOURCE: Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Posted on Apr 01, 2007
  • 4 Answers
SOURCE: encoder strip part c8941-80005
an encoder strip is seriously easy to replace! the strip rides thru a sensor on the ink cartridge carriage. one end hooks on to a small "hook"" on the left side of the plotter. the other end connects to a small "hook" on the encoder strip spring which connects to the right side of the plotter. Most manufacturers consider anything inside the case to be "not user replaceable". but really, its harder to keep the pictbridge bezel (cover) from falling out than it is to replace the encoder strip.
in response to jktyler.. my 2 year old did the same. if the small slots on the ends of the encoder strip are broken, then the strip is definitely damaged.
Posted on Dec 10, 2008
  • 3 Answers
SOURCE: Encoder Strip
tried for hours to reattach my encoder strip, and finally figured out the way to do it after reading many web postings, and my own trial and error.
The key is to use a "dental mirror" that you can pick up at a pharmacy or hardware store for about $5. (Perhaps a small compact mirror may also work.) And you need to focus light back there. (I used a head lamp.)
The problem is you just can not see the small slot through which the encoder strip must be threaded from the front of the printer. It sits in back of the ink cartridges. This thin slot "tunnel" goes though a rectangular piece of plastic. You can feel the rectangular piece of plastic in back of the ink cartridges, and looking with the dental mirror you can see how small the slots are on the right and left side, through which the encoder strip must be threaded. After "seeing" these small slots using the dental mirror, you then can feel them with the tip of a fingernail, and know exactly what you are aiming for as you then feed the encoder strip through. (It doesn't make any difference of you feed the strip from the left or the right, but the down arrow end of the encoder stip must end up on the right when you later attach it to the wire tab.) I fed the strip "blind" after I had formed a strong mental image of exacly what I was trying to do, and now being able to feel the small slot I was aiming for with the tip of a fingernail. (It is tough working in the small space in back of the ink cartridges, and if you have really big hands and fingers it may be impossible. I did not want to use forceps or tweezers because of a fear of damaging the encoder strip.)
The encoder strip then must be attached with the down arrow end on the right attaching to a flimsy looking wire on the right side of the printer. The left end of the encoder strip must be attached to a metal tab on the left side of the printer. You will need to hold tension on the encoder strip, and manually push the sliding ink cartridge back and forth out of the way as you attatch both ends.
(It's probably a good idea to gently clean the encoder stip of all your fingerprints and any smudged ink with a tissue after you get it back in place. Also be sure to clean the metal bar the ink cartridges slide back and forth on, so you don't get error message 0502.)
Be prepared for this to be a very frustating experience!
You will be maddened by how many times it will take to thread the encoder strip though the slot, how difficult it will be to catch the end of the encoder strip on the wire and metal tabs, and how you will have to figure out how to hold tension on the encoder strip so one end won't fall off as you attach the other end.
But once you use the dental mirror to see where you have to thread the encoder strip, and once you see the wire and metal tabs to which the ends of the encoder strip must be attached, then YOU CAN DO IT! It just takes persistance.
Posted on Jan 08, 2009
mace1mace
  • 1138 Answers
SOURCE: iS IT TRUE THAT THE CANON MX 320 IS THE WORST
Not really!!
You can try two different procedures to clear the error.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
The next procedure is also the key for making the old cartridge reusable after getting reffiled
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
If you bumped in to a different error codes See My
Helpful Tips for this Printer Pixma MX320 and MX328.
If this solve your problem please give some good ratings too as this will help me too. Thanks.
Posted on Aug 14, 2010
Canon Multipass F60 error
Encoder strip is the transparent strip which behind the cartridges carrier2b85ffb.jpg
A: Encoder strip (semi-transparent gray strip)
B: Carrier belt (black and brown toothed belt)
Please open the cover and check if the carriers is coming to the center ,if not gently pull the cart carrier to the center and then power on the printer , be carefully with encoder if its damaged then you cannot use the printer...
Good luck...
Oct 13, 2008 | Canon MultiPASS F60 All-In-One InkJet...
MFC-665cw unable to print 50
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment.
hen you open the printer so that you can see the print head, move the print head with your hands, pull it to the middle. The space immediately to the front of the printer is blocked by the plastic shield. you can curl your fingers down under this shield. you will feel the encoder strip, which is about 8 mm wide, and is a plastic ribbon, or strip. It runs from left side to right side across the printer, in a vertical orientation. This is the encoder strip. Past this you can feel a longer rubber belt, which is about 3 mm wide. This is not the encoder strip, it is a belt and you don't need to be concerned with this.
Place your fingers on the encoder strip on either side of the print head, and flex it, bending it up and slightly back and then release it. Try this several times. Do this with power on. Once the encoder strip is back into it's slot the printer will start a cleaning cycle and start working.
Solution found here originally.
Oct 16, 2012 | Brother MFC-665CW All-In-One InkJet...
My printer is canon mp198 while i trying to fix my ink cartridge, accidentally i pulled out a plastic strip that was located behind the ink placement cartridge. and now the ink cartridge moves very fast...
You have most probably snapped the end of the encoder strip (the pastic strip) as it is spring tensioned. Look at both ends and there is a square cut into it. one of then will be broken and only a new strip will fix it. You should be able to buy a new one from any canon supplier. i cant give you a part number as not a uk model. Oh by the way there is a right and wrong way around so look at the old one before removing it.
Jul 08, 2011 | Office Equipment & Supplies
The encoder strip has come off, how do I put it back on as I don't know where exactly it is supposed to go!!!
This article in the Lexmark website will give you an idea on how to re-seat the encoder strip in the carrier assembly: Printer Cartridge Stalls or Is Blocked
Apr 14, 2011 | Lexmark X6150 All-In-One InkJet Printer
Canon MP210 printer: There's a 3/16" wide by 16"
Hello.
Yes. That is the encoder strip.
Gently connect the strip on either end behind the carriage rod. The strip has an "L" on one side and a dot on the other. Be sure you put the "L" side on the left. There is a small **** behind the printer head that you must slide the encoder strip through before attaching.
After connecting, if the strip needs cleaning, moisten a clean cloth or tissue with water, then gently grasp the strip between the thumb and forefinger, and carefully pull the moistened cloth along the entire length of the strip in a right-to-left direction. Repeat this step with a different portion of the cloth to ensure that all foreign matter is removed.
Allow the encoder strip to dry, or gently dry the encoder strip with a clean, dry cloth or tissue. Position the cradle near the center, and then plug the power cord in the printer. Close the top cover to allow the print cartridge cradle to move bac.
Hope this helps.
Nov 05, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Service error 5100
5100 means the carriage is not moving properly, or there is grease or ink on the encoder strip The encoder strip is the clear strip with black lines behind the carriage that runs all the way across the printer. You can clean the strip with a Q-tip just damp with water.
Jul 28, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Printer problem
its a problem of the encoder strip . either the encoder strip is loosened or damaged.the carriage sensor reads the plastic encoder strip while it moves.if the sensor is not able to detect the encoder ,such a problem arises.u can check the position of the encoder and take the necessary step accordingly.if the encodder is damaged replace it.
good luck.
thanks.
Oct 27, 2008 | HP PSC 1410v All-in-One Printer
Printerhead problem
The problem with encoder strip please follow the steps given in this link: (note is the not canon but lexmark website but the problem is with encoder strip please follow the steps WARNING! Be very careful when cleaning or adjusting the printer's encoder strip if broken it may not work )
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS22722&relevance=0
Just follow the steps that it if unable to do it please cannon tech support>>>>>>>>>>>>>>
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
May 03, 2008 | Canon MultiPASS F60 All-In-One InkJet...
246 people viewed this question
k24674
jasbo
jasbo
