Question about Dishwashers
Frigidaire Dishwasher Won't run, the light is green on heavy load but won't start or cancel?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Well, I was gonna say make sure the door is latched, but most units won't even come on if its not. All I can think of is that their is something obstructing the sprayer blade? Otherwise, their is an issue with the programming itself. I suggest contacting the manufacturer and having them troubleshoot it with\for you.
Posted on Aug 30, 2014
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
Same thing happened - couldn't do anything - was completely "locked"...tried the breaker reset and it worked immediately. Thank you for sharing the answer!
Posted on Jan 10, 2010
  • 5160 Answers
SOURCE: Won't start/run. CLEAN light blinks
When the clean light is blinking, the self-test on the dishwasher has reported a problem with the heating circuit. It needs to be fixed. If the dishwasher is still under warranty, call for service.
The manual for the DU1100XTPQ9 is here: http://www.managemylife.com/mmh/owner_manuals/4164/WHIRLPOOL-Dishwasher-L0704454?brand_name_search=DU1100XTPQ9+WHIRLPOOL . Various parts diagrams and links to purchase the parts are here http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPQ9/1198/0130000 .
I hope this helps.
Posted on Jun 20, 2011
  • 3247 Answers
SOURCE: I can't get the control panel to reset. The
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Posted on Jun 24, 2011
  • 251 Answers
SOURCE: intake drain light is on and dishwasher won't
Hi there - possible the inlet valve is blocked or faulty - have a look at the valve if its blocked first if not then the inlet valve is faulty... the problem is the G638 has 2 inlets - one is the the waterproof syatem with a large grey contration fitted to the tap, the other is located beneath the machine , a bit hard to get at...
will require a disconnection of services empty water from machine - tilt on the back - 4 screws on the bottom tray - here you will find the valve - should be located on the frontish right side..
Do be careful if you pursue the latter as its a delicate with little space to work with and costly if you break something else in the process...
Have a think about this first...Yes? then do remeber to disconnect the power.....
happy weekend
Posted on Jul 01, 2011
Testimonial: "all fixed...thank you !!!!"
SOURCE: washing light is flashing and dishwasher won't
The dishwasher is getting water, but it is not cleaning the dishes and it will not even dissolve the dishwashing tab. The machine is less than a year old. We have had the electric go off, is there a reset button or something?
Posted on Jul 22, 2011
Frigidaire dishwasher has no power and won't start
Hi - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 17, 2012 | Electrolux Fridigaire Lp Conversion Kit...
GE GLD6700N dishwasher won't drain
remove the drain hose and make sure its not plugged with food debris then hit the drain/cancel button and put the drain hose end in a bucket and see how much water comes out of the end of the hose if any,if the 2 green lights are flashing this too is a clue to this problem,also make sure you can hear the drain pump running when you start it as explained in the above statement
Oct 16, 2012 | GE GLD6700NBB / GLD6700NWW / GLD6700NCC...
Reset frigidaire dishwasher model FDB1100RHC
I had the same issue. I unplugged the dishwasher and plugged it back in. Bam! It's working fine now.
Oct 16, 2012 | Frigidaire Dishwashers
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
The Whirlpool Dishwasher GU 2400 won't staart
Sometimes I have to push the cancel button on my Kitchenaid and start over and push the selection buttons again. and then push start. Don't know if this will help.
Jan 07, 2012 | Whirlpool Dishwashers
My frigidaire oven wont stop beeping and it has a f9 code
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Frigidaire FEB27S5A Electric Single Oven
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
156 people viewed this question
Top Dishwashers Experts
