Question about GMC 2004 Yukon XL 1500 Denali
Air conditioner gmc yukon not cold at all - GMC 2004 Yukon XL 1500 Denali
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Not enough r134a or orface tube blocked or ac clutch not coming on
Posted on Aug 04, 2013
2001 yukon gmc a/c blows cold to rear warmer air to front a/c
Could be a blend door problem under the dash.
Jul 05, 2012 | 2001 GMC Yukon
2004 Yukon. driver side air conditioner not working
you need to change drivers side temp door actuator then disconnect battery for 5 seconds and reconnect after changing the part, turn key on for 60 seconds with touching heater control to allow actuator to program and then it will work.
Sep 19, 2009 | 2004 GMC Yukon
I have a 2001 yukon with a front and rear air conditioner. The front works great the rear does not blow cold air?
neighbor had this problem with his yukon,found bad lines to the rear air.extremely expensive.good luck
Sep 06, 2009 | 2001 GMC Yukon
Air Conditioner Problem
the most common problem here is a defective air temperature control blend door actuator, this is what moves the door that controls air flow across the heater core or the ac evaporator core, to replace this requires u remove the dash assembly.
Aug 13, 2009 | 2005 GMC Yukon Xl Denali
The air-conditioner on our GMC Yukon does not blow cold when stopped at a light or such. The fan still blows, but the air is not cold unless the Yukon is moving. Can this be fixed?
Make sure that your coolant is full. That is usualy the cause.When you are at idle there is not sufficent coolant to be pushed thru the heater core.
Jul 08, 2009 | 2002 GMC Sierra
Fuse is OK but air conditioner doesn't work '94 GMC Yukon.
yes alow presure switch is likely on GM and it could be out of freon ,safe way to tell is to put a set of gauges on it and it will tell by passing the low side switch will just destroy the compressor if it is out of freon
Jun 28, 2009 | 1994 GMC Yukon
AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
Aug 25, 2008 | GMC Sierra Cars & Trucks
GMC 2004 Yukon XL 1500 Denali Logo
Top GMC Computers & Internet Experts
bigdawg7299
Jeff Armer
David Ellis Rhea
Are you a GMC Computer and Internet Expert? Answer questions, earn points and help others
