Question about Filter Queen Majestic Canister Vacuum
Wiring diagram i WANT A DIAGRAM FOR THE OUTLET CONNECTION
Motor needs replacement
Most manufacturers have all that information on their websites. Try visiting Bissell's website and in the search bar, type in "motor wiring diagram".
Apr 20, 2014 | Bissell 4104 Bagless Upright Cyclonic...
Does not work
1) TEST THE outlet receptacle wall, and reset the c.breaker
2) test the power cord for open or break wires and replace.
3) test the c.breaker or blown fuse inside
4) Test the drive belt for break
5) Test the motor for faulty. see the diagram attached and proceed with logic sense. God bless you
Jun 18, 2012 | Vacuums
I have an Electrolux Epic Model 6500sr canister apart and I need the wiring diagram for it Thanks Jim
Unfortunaly I don't have that wiring diagram. I am sure that the service manual can be ordred thru sears as they are the carriers for this material. What excactly is the issue and maybe we won't need the diagram.
Nov 21, 2011 | Electrolux Epic 6500 Vacuum
I nead a wirring diagram to fit a four connection power switch to a Kirby G4 cleaner
There isn't a wiring diagram for these. There is only a switch, a motor and a light, so a schematic isn't really required.
I'm assuming you've made the fatal mistake of removing the wiring from the old switch and have forgotten where to re-connect them. It's also not very helpful that all the wires are white, so I can't really tell you to connect red to "x", black to "y", etc.
The really important connections are the power cord and the motor brush connections. You can't get the power cord wrong as the plug is shaped to only allow connection at one orientation: I've drawn you a diagram to show 3 of the 4 connections:
As long as the motor brushes are correct, there wont be any problem. If these are the wrong way around, the motor will run in reverse and will blow instead of s/uck.
The headlight can be wired either way around so if these connections are switched, it shouldn't matter. You have a 50/50 chance of getting it back the same way as it was originally and if there is any problem with the light, you can easily switch these wires over.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Kirby G4 Bagged Upright Vacuum
Need a readable motor wiring diagram for Eureka Vacuum Bagless Upright 4388.....
take the black lead of the power cord to one on-off switch lug, then take wire off other switch lug to one motor connection terminal, brilg other motor terminal wire back to other wire on the line cord.simply a series power circuit
Sep 27, 2009 | Vacuums
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
37 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
