Question about Bernina Virtuosa 150
Bernina sewing machines
I have just recently had this machine serviced and I oil and clean it regularly but it continually skips the bobbin stitch - the top thread does not always pick up the bobbin thread.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Did you mention this specifically to the repairer? Could be a number of things ..... needle, timing, needle clearance to the hook, burred hook...... all of which should have ben checked when it was serviced. Was there a sample (sewn out by the repairer) with the machine when you picked it up? ie to 'prove' it was working correctly.
Posted on Apr 29, 2014
  • 106 Answers
SOURCE: Bobbin thread not picking up
Glad you managed to fix it yourself, in addition to the 250kms I would guess the cost would have been a lot.
Posted on Apr 01, 2008
SOURCE: Bernina 801 Sport
Did you clean out the lint under the plate?
Posted on May 18, 2008
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
i_luv_2239
  • 12 Answers
SOURCE: The needle thread will not pick up the bobbin thread
It looks right but its not. Try looking on the internet for threading instructions. The bobbin winds in two directions, I have never saw a Bernina but I have 2 new machines and the thread goes in and then threads back to the left. Its hard to describe. But if the bobbin isn't right it will not pick up the thread. Write to Bernina for instructions. There are websites that have the directions for free.
Posted on Nov 19, 2008
rylee_smith
  • 8619 Answers
SOURCE: machine problem
Hi!
There are so many reasons due to which the thread is not picking up from the bobbin like:
The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be threaded incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
Do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 01, 2009
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Red light system will knot come on
Is it a Bernina 930 Record (a mechanical machine)? If so, have you cleaned and oiled your machine recently? Could be some of the moving parts have dried out and are sticking. Use only fresh good quality sewing machine oil and apply 1-2 drops of oil each spot (note--there are a lot of oil ports in the machine that will help keep your machine working). The problem you are experiencing probably emanates from the stitch selectors at the top of the machine, so be sure to oil and exercise those. Do NOT oil plastic parts, belts, cams, and stay away from the Bernina basting stitch at the middle of the needle bar.
You should apply a drop of oil at the shuttle/hook area every time you install a new bobbin, perform a thorough clean and oil every 40 hours of sewing or, if in storage, every six months.
Bernina 930 oil guide:
Jan 03, 2016 | Sewing Machines
Will not zigzag or decorative stitches. New to these newer plastic style machines Always used older steel machines. This was given to me my by my sister who used it very little. Could cam be broken?
Hmm, I'm wondering if it has been cleaned and oiled recently. Older mechanicals require frequent TLC. Consult your owner's manual for cleaning and maintenance instructions:
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil or liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
Dec 30, 2015 | Singer 6038 Mechanical Sewing Machine
Bernina Record 730 hand wheel stuck
OK OBRIGADO VOU LIMPAR A MAQUINA PODE SER POEIRA PORQUE FICOU ALGUNS MESES SEM FUNCIONAR.
aGRADECIA SE ELA FUNCIONASSE TENHO MUITOS TRABALHOS POR FAZER SOMENTE O ERROR C14A3 ESTA A BARRAR-ME E NAO ACEITA MAIS NADA A FUNCIONAR
Feb 06, 2014 | Bernina Sewing Machines
Bernina 930 Electronic
Try cleaning and oiling your machine (refer to the owner's manual). Perhaps the stitch width selector has become stuck with old oil. Mechanical Berninas should be cleaned and oiled regularly--it every time a bobbin is changed, every 8 hours of constant sewing, or every 6 months of non-use.
Dec 10, 2013 | Bernina Sewing Machines
My wheel will nor turn and my machine will not sew on my 930
sounds like it's time to have the sewing machine serviced.
Feb 07, 2013 | Bernina Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Old style 830... having trouble doing automatic stitches
Take the machine to an authorized Bernina dealer for service - make sure to fill out the service slip with any problems you are having.
Mar 05, 2010 | Bernina Activa 130
Bernina Record 930 Electronic, seldom use, like new. Wheel will not move. Was doing stright sewing, machine slowed down then froze. Maching is clean. No instruction book or manual. Machine belongs to my...
Bernina 930 Records are notorious for the basting stitch sticking which eventually locks up the machine. To prevent this from happening, be sure to run the basting stitch for a few minutes every month. If it is stuck, you'll need to take it to a Bernina technician.
If it is not the basting stitch, it could be a broken plastic gear (trip to the Bernina technician) or it needs oiling.
If it is not a broken gear, then it probably needs oiling. Your Bernina mechanical requires regular oiling and cleaning even if you don't use it (ie, every time you change the bobbin, every 8 hours of sewing, or every 6 months if not in use). HINT: recommend Bernina oil or similar good quality oil for mechanical machines, NOT 3-in-1 oil, WD-40, or cooking oil!!! One or two drops of oil in every oil hole and every place that metal part rubs against metal part.
Treat your Bernina well and it will serve you well for many years.
Oct 23, 2009 | Bernina Sewing Machines
Sewing Machines Logo
93 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
