Question about Bosch Washing Machines
Bosch wfk 2200
The machine gets to the rinse cycle, usually the final rinse, then stops with a flashing 2 error code.
  • 1294 Answers
SOURCE: WF860 error code
Click on your model numbers (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. You might find the mysterious codes there.
And dont forget to rate me on this great site.
Posted on Jan 17, 2008
  • 409 Answers
SOURCE: My Bosch WFK 2401 keeps
hi there,
the 03 error message is the machine not sensing the water level. since you can drain using the pump manually, check the water level switch, as it may be faulty.
Posted on Oct 05, 2008
SOURCE: I have a Bosch washer, model number WFK 2401 that
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Posted on Aug 06, 2009
beltronic205
  • 1460 Answers
SOURCE: Bosch wfk 2200 will not stop filling with cold
If still fills with machine off. Says solonoid valve faulty spring replace valve..
Posted on Nov 04, 2009
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Hi, the spin cycle on our bosch wfk 2401 suddenly stopped working. The wash and rinse cycle works but when it's time for the spin cycle to begin, the machine hums as though the motor is straining...
If there is motor humming while the spin cycle is ON , please confirm if the motor also heats up-- take caution not to touch live points. Also if you manually push the motor with care so see if the spin starts up then the capacitor (this assists with the starting) can be weak or faulty.
Remove and check with a mains tests and see if the charge retains, if not change. Other wise check if there is friction on the motor or drive.
Jun 14, 2011 | Bosch WFK 2401
Bosch wfk2401. machine stops and lights start blinking " error code 03"
washing machine does not spin on any cycle , however the belt is fine. Any recomdenations
Jun 13, 2011 | Bosch WFK 2401
What does flashing error code 2 on Bosch a WFK 2800 washing machine indicate
Problem from heating. Could be element or wires from it
Oct 21, 2010 | Bosch WFK 2401
I have a Bosch 2401 washer. When I set the cycle and push the On button the Pre Wash, Rinse Plus, and Power Wash lights flash, and CL appears on the display. Pressing Start does not work. I tried the self...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The 03 error code is the drain. Disconnect the drain hoses and check for blockages, look for block at end of exit hose. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Pl rate me ‘very helpful’ for the free help!
Jan 23, 2010 | Bosch WFK 2401
My Bosch WFK 2401 keeps giving me the 03 error message, the pump looks fine when I drain it manually (which takes 1/2 and hour!, now I don't bother draining it completely, I just drain a bit of water from...
hi there,
Oct 05, 2008 | Bosch Washing Machines
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Washing Machines Logo
18 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
