Question about Toys
Instructions roboreptile will not respond. Tried new batteries. The remote lights up but when switching roboreptile on it does nothing.
techman
  • 3130 Answers
SOURCE: Remote Control
Go to http://www.remotes.com and get a new remote.
Posted on Sep 27, 2006
Doodad
  • 64 Answers
SOURCE: TV does not respond to remote
Sounds like the sensor on the television has gone bad, since it works for the VCR. Try a universal remote that you can program the TV and VCR codes into and try it out. If it works for the VCR and TV then you know it's the remote, if the TV still isn't responding then your TV sensor is toast.
Posted on Jan 03, 2008
DeeJStat
  • 5 Answers
SOURCE: remote
If the fan is not responding to the remote. Then it is the controller inside the fan. To order a replacement part contact "King of Fans" who owns the warrenty for Hampton Bay. The number is 800.749.3267 for about 43.00. Hope this helps.
Posted on Jun 08, 2008
SOURCE: My Logik L22LID628 tv has
We have had two of these tvs break within 2 days of purchase, in our case both times it seems to be a backlight failure. Did you wall mount your tv? If so when you take the base off it leaves a hole in the casing leaving circuitry visible. I think it's very easy to damage the ciruitry.
Posted on Nov 03, 2008
SOURCE: my 32" sharp lcd doesn't respond to the remote
Ok I just dealt with the Sharp customer support for this problem. 1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
... let me tell you I thought the lady was crazy when she was telling me this but it worked!
Posted on Jan 01, 2009
Roomba 4106 new battery charged but wont start
see the diodes, resistor, capacitor inside for test.
since the battery is new, the power charger is faulty, power regulator IC is bad.
God bless you
May 16, 2012 | Roomba 3005 Pro Robotic Vacuum
We have a '94 XJ6, I get nothing from a run>>>start.
there are 2 connections on the bulkhead/firewall. There is one on
each side.The connectors are brass and the insulators are
plastic with a rubber boot. unless these connections are clean you may get all sorts of malfunctions with switches,lights and electric
motors. Symptoms are similar to a failing battery, something to start with..
good luck
Apr 01, 2010 | 1994 Jaguar XJ6
Tv slowly started to not respond to remote control. now it does nothing and we have to manually turn channels. i have tried every code to reprogram the universal remote, and nothing works.
I don't intend to be a smart *** but, have you changed the batteries?
The "slowly started to not respond" is a key indicator of dead batteries in a remote.
Mar 20, 2010 | Televison & Video
The ON button on the Wii remote doesn't respond. Tried new batteries but still no response. No blue lights, nothing! Tried patting it, reset button, all instructions as listed in troubleshooting. Had since...
Try reseting the wii console. This is done by removing the battery from the botton of the console. There is a small battery bay held in by 1 screw. Leave it out for a day and after you install it make sure you press the conect button on the wii. (located under SD card reader door). And the connect button on the controller (located in battery compartment on back of controller). Good Luck.
Nov 24, 2009 | Nintendo Wii Console
Fan not responding to remote
Check to see if the remote switches of your hand held device match the switch setting in the fan assembly
Sep 15, 2009 | Hampton Bay 52 In. White Redington...
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
No response from remote
user manual
FINALLY no need to thank me
User Manual
Aug 31, 2008 | Televison & Video
Coby 626 DVD Player Remote Not Working
I have a COBY DVD player TF-DVD7005 that hadn't been used in a while. When I charged the battery and the light went from red to green, nothing happens when I push play and the DVD doesn't spin. Could the battery be dead despite the green light and where would I get a new one?
Mar 18, 2007 | Coby DVD-224 DVD Player
Toys Logo
23 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
