Question about Goodmans W280NS Television
Goodmans Flat Screen 42" Plasma TV
Our TV for no reason will turn itself off but the red button will remain on and it will flash green occasionally. We have banged the TV box and turned it upside down which after a while will aloow the TV to come back on but the problem will re-occur.
  • 372 Answers
Hi. What you are discribing sounds like dry solder joints in the media box. Because of the delicate circuitry in the box I would recomend you have media box looked at by a shop. Your best bet is a small independent retailer rather than the big boys currys etc. I have personally dealt with a company that repairs the boxes who advertise on Ebay UK. They do A repair or exchange service for approx £90.00 all fully waranteed. They fixed A techwood media box that was driving me crazy & since being repaired has caused no problems.
Posted on Sep 04, 2007
SOURCE:
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
50PF9631D won't turn on... red light flashing/blinking 6 times
Your TV main board is damaged and you need a new one. You can order one on ebay and fix it yourself. Make sure you have the TV model/serial number on the back label of the TV to have the right part when ordering.
Jan 09, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Red and green flashing boxes, will not turn "on".
the epromm chip on the mainboard needs to be change
Mar 22, 2008 | Pioneer PDP-425CMX 42 in. Plasma...
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
192 people viewed this question
Top Goodmans Televison & Video Experts
Ekse
Colin Stickland
Colin Stickland
Steven Wander
Steven Wander
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
