Question about Microwave Ovens
Got a lamona hja2440 the buttons don't work? Any
caroldon
  • 17130 Answers
SOURCE: Oster ogf41101, unit display doesn't work, when
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Posted on Jun 14, 2011
KevinWhite
  • 1902 Answers
SOURCE: Maytag Microwave - Model MMV4205AAQ.
Hello & Welcome to FixYa
If the door is closing properly and completely then the problem is with the control board that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Aug 06, 2011
  • 403 Answers
SOURCE: fan works, but doesn't cut off ...no light comes on, push buttons but nothing happens
U need to replace the control
Posted on Dec 22, 2011
  • 6771 Answers
SOURCE: buttons won't work
The problem is in the keypad control board, or smart board. I recommend a estimate because cost will be high.
Posted on Apr 02, 2012
  • 6771 Answers
SOURCE: GE Microwave VM240 AV underchassis fan & light don't work
It is more than likely there are one or two defective door switches that need to be replaced.
Posted on May 08, 2012
How can I reset clock on Lamona HJA7030 microwave. I have followed instructions in manual without success
Press the clock button for 3 seconds: the hours digit will flash. press the +/- to set hour. Press the clock button again: the minutes digits will flash. Use +/- to set. Press the clock button again. Done....
Oct 29, 2017 | In Microwave Ovens
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Oct 01, 2012 | GE Microwave Ovens
Maytag microwave keypad
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Troubleshoot maytag keypad control board
Oct 01, 2012 | Maytag Appliances Over-the-Range Microwave...
Most of the buttons on my Goldstar MV1604SB stopped working
Does the display on your microwave read "Locked"? If so, then the Child Lock feature has been activated. To toggle the lock off, press and hold the Stop/Clear pad for more than 4 seconds. When this feature is active, most buttons are disabled to prevent accidental microwave use.
If holding the Stop/Clear button doesn't work, then I'd suggest there is a problem with the contacts behind the buttons. Sears Parts Direct has the parts diagrams for this microwave here: http://www.searspartsdirect.com/partsdirect/part-model/Goldstar-Parts/Microwave-Parts/Model-MV1604SB/1366/0123245 . (It's better to replace the control panel then to try to fix it.) Use the part numbers from the list to find price and availability at other sites.
The manual for the MV1604SB is available from Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17638/GOLDSTAR-Countertop-Microwave-L0521424?brand_name_search=loosening+tight+screws .
I hope this helps.
Oct 13, 2011 | Microwave Ovens
I don't know what it means when it say control lock
typically when you hold down the lock button for 5 seconds it disables all the other buttons so a child cannot operate it for safety sake.
Jul 24, 2011 | Microwave Ovens
How do i unlock my lg microwave i dont have an owners manual so i dont know how to unlock it
"Locked" meaning the buttons don't work/non-responsive (Child Safety Locked)? To Unlock/Disengage the Child Safety. Push and hold the "Clear/Off" button for 3 to 4 seconds. The Child Safety is disengaged - problem solved.
Nov 15, 2010 | LG LMVM2277ST Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
