Question about Ricoh Aficio MP 161 Black and White Copier
Mp 161 how do i replace the photo conductor unit
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Open the right cover where you normally remove the paper jams,then open front cover/door where you put toner,lift the green handle up,push green lock towards the right side while pulling the hopper out,then theres a connector beneath the PCU,pull it then pull out the PCU,use the same same procedure to put it in,start with the PCU,return the connector and put in the hopper,then close all doors/covers
Posted on Mar 07, 2014
2 Suggested Answers
Arius
  • 446 Answers
SOURCE: Color Photo Conductor Unit
the vertical line that you saw is an indication of either it is normally worn out, or something has caused the scratched, by any material ( PC drum is very sensitive to any material and can easily damaged or scratched any solid and unwanted dirt inside) see you actual meter reading. if it falls on the first thousand copies or print then it might have caused by a scratched, if it falls beyond the PM parts repalcement then there is nothing you can do but to replace this.
sometimes you can swap the colors, by the affected color use the yellow drum unit to the affected drum, the vertical would not that be obvious.
Posted on Jul 24, 2008
What does 500 mean
Main Motor error(stuck). Replace Photo Conductor Unit.
Jul 15, 2015 | Ricoh Aficio MP 201SPF Fax Machine
My ricoh mp 1900 ink fades away after printing and the cartridge is full . what do I do?
Have you tried cleaning the laser unit? Usually thats the problem, or you need a new PCU (photo conductor unit)
Jul 14, 2014 | Ricoh Office Equipment & Supplies
How to clean Ricoh Aficio MP 2000
sounds like either drum blade has fail or drum is bad. try printing the counter report and see if it is doing this. Then photo conductor unit needs to be rebuilt or replace. open right side door and look at drum make sure you don't touch it and see if toner is on it. If so drum blade has fail. call a tech or buy new photo conductor unit. this are good for approx 60,000 copies but sometimes will go longer age also play with drum blade life. were you might have 20,000 copies but unit is 5 years old
Jan 31, 2012 | Ricoh Aficio MP 2000 Black and White...
IS THERE A TRICK TO INSTALLING THE PCU ON THE CL3500N? IT SEEMS AS THOUGH IT SHOULD BE A SIMPLE PROCESS HOWEVER IT IS NOT LOCKING INTO PLACE. THANK YOU
Photo Conductor Unit Color
A Turn off the power, and then unplug the power cable.
B Open the right cover.
C Pull out the green levers on the left and right that are securing the inner
cover.Replacing
D Lift the inner cover until it stays up.
E Remove the photo conductor unit.
F Pinch the
green lever to unlock the unit.
G Pull out the photo conductor unit carefully.
H Pinch the green lever to unlock the unit.
I Pull out the photo conductor unit carefully until it stops.
J Pinch the green part to release the unit
.K Pull out the photo conductor unit carefully. Be sure to hold the unit with both hands, and pull it out carefully.
L Take out the new photo conductor unit.
M Remove the cap attached to the photo conductor unit. The cap is no longer needed and can be disposed of.
N Remove the tape from around Photo Conductor Unit by peeling it down-ward, and then remove the unit
Mar 11, 2011 | Ricoh Aficio CL3500N Laser Printer
REPLACE PHOTO CONDUCTER ERROR
photoconductor is the main unit in the machine. it has done its life of 60,000 copies so it requires replacing. if you open the front cover. the photoconductor unit is locater beside toner supply unit.
Dec 13, 2010 | Ricoh Aficio MP 161 Black and White Copier
Pc drum
Replacement of the Photo Conductor Unit
1. Select Tech. Rep. Mode → [Counter] → [Special Parts Counter] → [PC Life].
2. Press the Clear key to clear the counter value.
3. Turn OFF the main power switch.
NOTE
• Clear the PC Life counter before removing the IU.
• After clearing the PC Life counter, be sure to turn OFF the main power switch.
4. Open the Right Door.
5. Remove the IU. Carefully pull on the two green handles
6. Remove four screws (silver) on the sides and disassemble the Photo Conductor from the Developing Unit.
7. Replace the Photo Conductor Unit
8. To reinstall, reverse the order of
removal.
NOTE
• Replace the Toner Filter (Developing
Unit) with a new one at the same
time.
Jun 06, 2008 | Office Equipment & Supplies
Ricoh Aficio MP 161 Black and White Copier Logo
156 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
