Question about Western Digital WD2500BEVS Scorpio 250 GB 2.5-inch SATA SATA Hard Drive
Jumper setting sata drive western digital scorpio scsi eide
    New Friend:
  • 62 Answers
Look for your model number on Western Digital's support site:
http://support.wdc.com/product/install.asp?groupid=701&lang=en
Posted on Feb 13, 2015
2 Suggested Answers
dahaka
  • 347 Answers
SOURCE: got a western digital Eide 250GB hard drive(internal), will it work in my Compaq SR5000 ? ( with the Sata hard drive)
Hello gunsun,
May i know what your problem is?
Posted on May 06, 2008
Western digital wd2500bevt slave jumper settings
SATA drive position is determined by the plug on the motherboard, not a jumper. Jumper settings are for PATA drives (much older).
Feb 06, 2014 | Western Digital WD Scorpio Blue WD2500BEVT...
Jumper setting
SATA drives require no jumper settings
Nov 30, 2013 | Western Digital WD Scorpio Blue WD2500BEVT...
Driver fro WD1600XMS
SATA drive doesnt require drivers or jumper settings
Nov 20, 2013 | Western Digital Scorpio WD1200BEVS 120 GB...
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
Jul 07, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
On a wd 750gb hdd 2.5 how do i chage it from 3.0gb to 1.5gb
jumper between pins 5 & 6. http://www.wdc.com/en/library/eide/2579-001037.pdf for more info
Feb 13, 2011 | Western Digital Scorpio Blue 750GB SATA...
Need to find the pin setting for a wd 1200bevs hard drive.
If you are talking about the jumpers on the back, here is a picture of the settings...
Aug 16, 2010 | Western Digital Scorpio WD1200BEVS 120 GB...
Trying to install the drive on my laptop, but it refuses to be seen as anything but the slave drive. How do I switch it to master? It has no jumpers on it.
This is quite strange, since without jumpers you should get a master device, not a slave one. Check with Western Digital 2.5 EIDE jumper sheet:
http://support.wdc.com/images/kb/4-Pin_JumperBlock.JPG
Verify that there are no "stealth" jumpers (small flat ones without the black plastic guard) and that the pins are not bent or shorted.
Mar 18, 2010 | Western Digital Scorpio 160GB Internal...
My Computer did not access Western Digital Hard Disk, Model No. WD 1600 AABB Caviar SATA.
Good morning! Please make sure that the drive’s power and SATA cables are properly connected. If the Serial ATA host adapter card is installed in a 64-bit PCI slot on the system motherboard, move the card to a 32-bit slot.
Verify that only one power cable (either SATA or legacy) is connected to the drive. Check to see that the power connector and SATA interface cable are securely attached and that the
SATA host adapter card is properly seated in the PCI slot.
The Serial ATA interface connects each drive in a point-to-point configuration with the built-in SATA port on the motherboard or with the SATA host adapter card; therefore eliminating the master/slave relationship as required with EIDE. Each drive utilizes its own
cable for data transfer rates. Jumper settings for Western Digital Serial ATA hard drives are mainly used for enterprise storage environments.
Most third party controller cards and RAID adapters are recognized as a SCSI device under Device Manager. This is normal and will not affect your drive or system performance.
To verify if the Serial ATA drive is recognized by the system, Right-click on the My Computer icon, select Properties, left-click on the Hardware tab, and click on Device Manager in the window. Double-click on Disk Drives. Your new Western Digital Serial ATA drive should be listed as a "SCSI Disk Device" or "Serial ATA Disk Device." If not, make sure that all cables are securely attached and that your system BIOS has been properly configured. regards
May 12, 2009 | Computers & Internet
Western Digital WD2500BEVS Scorpio 250 GB 2.5-inch SATA SATA Hard Drive Logo
153 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
