Question about Norpole 8000BTU Window Air Conditioner w/Remote
Norpole home window ac wiring diagrams
Fell out of window and all the wiring came out inside and main power plug ac is new and need to know how to wire it back up completely
Leviton RC 1000. I replaced the old HAI thermostat with a new RC 1000. Four wires to drive furnace and AC, there was no common wire attached. I also connected the thermostat to my HAI controller per the...
it might not be compatible with the furnace and ac system you have. I would make sure that it is, also read the manual book some wires you can tie in together to plug into the same lead. JUST FYI AC and Furnaces are really fancy now and have a computer chips in them... so i would investigate.
Nov 24, 2014 | HAI Omnistat2 RC-1000 Thermostat
Remote control
buy a cheap universal remote for ac will do.
Jun 03, 2013 | Norpole 12000 BTU Window Air Conditioner...
Wiring diagram battery pack aspire 5580
Are you asking for the wiring diagram inside the main Battery?
If so, due to very possible injury, or death to you, there will be No solution.
Now, if you are talking about what is the polarity for the plug of the AC adapter, (Charger), that plugs into the DC Power Jack on the laptop, (DC _IN), then I'm on board.
The Center Hole in the plug end is the Positive ( + ) connection.
This is where the Positive (Red) probe lead of the multimeter goes.
The cylindrical outside metal shell is the Negative connection.
The Negative (Black) probe lead of the multimeter touches here.
Voltage is 19 Volts DC.
Wiring diagram for the inside of the AC adapter itself?
No gottom.
Regards,
joecoolvette
Oct 22, 2012 | Acer Aspire 5580 Notebook
I need a wiring diagram for 1986 28ft. winnebegohome to power pole
Copy following link to see basic wiring from pole, to your pole, and then to your circuit breaker box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Aug 27, 2012 | Electrical Supplies
HOW TO REPLACE THE FUSE
Fuse is located inside, just in the AC main connector pcb, very easy to see it, just take apart the amp by unscrewing the plate with a phillips screwdriver, don't pull so hard, as it has a wire connector to hook up amp with speakers, let me know if i can help more.
Jul 29, 2012 | Mackie SRM-450 System
Need wiring diagram for a 1974 Fleetwood Glenbrock mobile home
FIXYA DOESN'T HAVE ANY WIRING DIAGRAMS, SORRY.
Jul 09, 2012 | Cars & Trucks
Wiring for Goldstar R5050 window A/C
Yes I accidentally drop my Gold Star Model #R5050 out the window while installing it. I opened it up and the two(2) white wire are off and I don't know were they go. I try to connect the to the empty terminals and I got a spark out of the outlet. Can you please help me....
May 13, 2010 | Goldstar R5050 Air Conditioner
Window problems electric powered off track
Unless the motors were replaced at one time, the only bolts holding the window to the regulator are at the slides. any hardware that fell apart should be inside the bottom of the door. Panel removal is pretty simple..only hidden fastener is on the edge...small reflector has one under there.
Haynes makes a good reference for that car for about $20.
May 22, 2009 | 1996 Pontiac Grand Am
Norpole 8000BTU Window Air Conditioner w/Remote Logo
24 people viewed this question
Top Norpole Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Norpole Heating and Cooling Expert? Answer questions, earn points and help others
