Question about Quest Queen Air Mattress
Quest air mattress
Love the mattress: however, even tho it has a pad on top, the mattress itself was COLD. during the night, i had to lay 5 blankets on top of mattres & was then still cool. i could not sleeep, i was freeaing all night. any suggestions on how to get/keep the air warm?????????
I am looking for a replacement for 1 of the controls for my heated mattress pad. Where can I find 1?
www.sunbeam.com/.../bedding/controls/bedding-contr...
Sunbeam ProductsHow do dual controls work? The dual ... What if my control does not regulate my side of the warming product? ... Where can I purchase replacement controls?
Finding Replacement Cords and Controls for an Electric ...
www.thriftyfun.com/Finding-Replacement-Cords-and-Controls-for-an-El...
... blanket. Finding a replacement cord or a control for an electric blanket can be difficult. ... My blanket was under warranty and I got one for free. If yours is out of ...
Finding Replacement Controls for a Heated Mattress Pad ...
www.thriftyfun.com/Finding-Replacement-Controls-for-a-Heated-Mattre...
This is a guide about finding replacement controls for a heated mattress pad. It can be very frustrating to find replacement ... Read all 1 Answer ... Where can I findreplacement controllers for my Living Quarters heated mattress pad? By Steve.
Replacement Controls for a Sealy Electric Blanket ' ThriftyFun
Dec 07, 2015 | Sealy Heated Queen Size Mattress Pad - -
Can electrical cord for electrical blankets go between mattress and box spring
Wires should be on the floor. Do not put them where you may lay on them and or cause friction on them (even if it's just rolling over during the night).
Sep 19, 2014 | Sunbeam Twin Electric Auto Heated Blanket-...
Why has my heated mattress pad stopped working?
Electronics fail. Sounds like the digital controller has failed. A Google search finds others with the same problem. Biddeford models come with a 5-year warranty, so if yours is less than 5 years old, I suggest you contact Biddeford by telephone: 800.789.6441 or visit their website: http://www.biddefordblankets.com/warranty.asp
Sep 15, 2014 | Biddeford Blankets Heated Mattress Pad...
The air mattress was working fine the night before and then last night did not want to inflate. The motor does not start, it is plugged in, the socket works. I plug it in and go to turn the know to inflate...
most likely if you pump is not working, the intake must be clogged preventing air from passing and cooling the pump. That's how pumps and things like hair dryer short out. Or something could be blocking the fan from starting.even the power cord could be bad, I would check those things and go from their.
Jul 08, 2014 | Swiss Gear SwissGear Queen Raised Double...
How do i get the alarm to stop and what is making it go off?
Having the same problem. Pressing alarm mute only works for 5 minutes. The bed has pressure sensors so it knows if a patient has fallen out of bed, alerting a care giver. It may have something to do with those sensors. Try adjusting the inflation weight setting. Also, too many sheets/blankets on the mattress CAN give it a false pressure reading. Try both adjusting the weight AND removing unnecessary weight from the bed.
Apr 28, 2014 | Mason AS8800 Low Air Loss Alternating...
I have lost the cap to my Quest queen air mattress. How can I get a reeplacement?
You can find a pair of Boston valve caps by Kwik-Tek on Amazon for $5. I don't know for sure for you, but I've never met a boston valve that these don't fit.
Jun 01, 2013 | Camping, Backpacking & Hiking
Electric blanket won't heat
Take the help of your mattress pad company or look into instruction manual. Do not operate it unless you are familiar with it. You should call the customer care to know how to operate.
Jack from Coriumdirect Mattress pads
Apr 07, 2013 | Biddeford Blankets Heated Mattress Pad...
Do air mattresses deflate throughout the night?
When air mattresses first came out, deflating was a major issue. In the last ten years or so, all air mattresses built don't have that problem unless they have a puncture somewhere.
Feb 20, 2013 | Camping, Backpacking & Hiking
A few years ago I purchased a SlumberAir Mattress system by La-Z-Boy and I love it. It is the bed I sleep in every night, but I've run into problems with the air mattress. It seems after three m
You should check the coil mattress cover. Feel around to make sure nothing is puncturing the bladder. It is not normal for them to fail like that. When you deflate it, you must make sure all of the air is out of the bladder before folding the unit back into the sofa. If you don't, you make end up with a problem at the seams.
Sep 16, 2012 | la-z-boy.com
When air mattresses first came out, deflating was a majorissue. In the last ten years or so, allair mattresses built don't have that problem unless they have a puncturesomewhere.
Jul 09, 2012 | Camping, Backpacking & Hiking
Quest Queen Air Mattress Logo
352 people viewed this question
Top Quest Rock & Ice Climbing Experts
RatanbssBD
Level 1 Expert
Bill Boyd
Are you a Quest Rock and Ice Climbing Expert? Answer questions, earn points and help others
