Question about Arcade Manufacturing Co Antique 1889 Wood And Cast Iron Coffee Mill Or Grinder
Value of arcade mfg. coffee grinder imperial mill no 147
How can we fix a nutri-mill wheat grinder?
can you see the grinding wheel /blades . if so try to rotate it /them slightly by hand
Dec 17, 2015 | Nutrimill Grain Mill Grinder
Can I grind coffee in an electric grain mill?
Electric grain mills were not designed to grind up oily grains like coffee, you would be better off getting either a hand grinder or a coffee grinder.
Jan 23, 2014 | Kitchen Appliances - Others
Can I use a coffee grinder to mill grains?
You can although I have found that the coffee grinder doesn't mill the grains down to a fine enough powder for making flour though.
How do I clean my coffee mill/grinder (Models IDS50, IDS55, IDS57, IDS59)?
Clean your coffee mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Unplug your coffee mill.
  2. DO NOT PLACE THIS COFFEE MILL IN WATER. DO NOT IMMERSE THE BLADES OR MOTOR BASE IN WATER.
  3. Remove the coffee mill cover and brush. Wash both in warm sudsy water. Rinse and dry each thoroughly. The cover and brush are NOT dishwasher safe.
  4. Use the Built-In Cleaning Brush to sweep out excess grounds. Use a clean cloth or paper towel to remove any remaining grounds.
  5. Be sure to clean your coffee mill completely after each use.
  6. Do not try to oil or sharpen the blades. The blades are permanently lubricated and never need sharpening.
Sep 02, 2011 | Bunn NHB Coffee Maker
What are the maintenance procedures for the Pasquini mod. GMMC coffee grinder?
If this is in reference to the Pasquini K2 Moka Grinder, they are pretty much maintence free. Remove the beans/hopper, then pushing the button on left hand side down, you can unscrew the dial counter-clockwise. This will give you access to the top/bottom mills. Use a wire brush the machine came with to clean the coffee off from the mills teeth which builds up over time. Then reassumble and readjust your grind for the beans you are using.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Apr 06, 2010 | Pasquini Moka Coffee Grinder
Ave an SAECO INCANTO RONDA with milling problems.
You can turn the grinder (mill) so the plates open for a more gross coffee this will help the grinder motor to rotate more free you can use a vacume cleaner to **** all the remainig coffee inside the grinder. If still not any reaction you have to desasemble complete clean the grinding plates. If you still not have any reaction then the grinder motor burn out and need to bee replaced.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
Zassenhaus knee coffee mill grinds too coarsely
I have a Zass and sometimes have a problem with it self adjusting, but when I do need to adjust it, I find that I have give it a good tap on the top to make sure it adjusts. So, just turn the knob counter clockwise as far as it will go, then give it a good knock on the top and bottom and try again. My mill offers the full grinding range, from a fine powder to large chunks.
Feb 04, 2009 | Zassenhaus Knee Mill Hand Crank 156 Manual...
DeLongi coffee mill #DCG-4TB
DeLonghi PARTS AND ACCESSORIES
1 (800) 865-6330.
8:30 a.m. – 5:00 p.m. (EST) Monday through Friday.
Oct 24, 2008 | DeLonghi Electric Coffee Mill Grinder
Osyer burr mill 6389
Apparently, you unplug the unit, dump any beans out of the supply hopper, then rotate the burr intake module in the bottom of the supply hopper counterclockwise. You can then pull it out, and brush it out. You also brush out the other half of the burr unit; don't put water or anything in it, you'll kill your grinder. You can, in theory, wash the removable module, but if you do, be sure it's ABSOLUTELY dry before you put it back together.
Jun 15, 2008 | Oster Coffee Burr Mill - 6389 Grinder
Arcade Manufacturing Co Antique 1889 Wood And Cast Iron Coffee Mill Or Grinder Logo
203 people viewed this question
Top Arcade Manufacturing Co Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Arcade Manufacturing Co Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
