Shadow on image
There is a shadow in the lower left side if image, looking into the lens I see a little obstruction inside. Can u help"?
  • 25 Answers
Usually, this is just caused by dust inside the optical block. It can usually be remedied my removing the lamp, and just blowing out the unit with an air compressor. Canned air won't do the job.
Posted on May 01, 2013
SOURCE: shadow image acrooss screen
THIS IS TUNNEL PROBLEM
Posted on Jan 23, 2008
SOURCE: Blue "Shadow" to Left of White Objects
I'm in the same boat. Help please!
Posted on Mar 21, 2008
SOURCE: Mutilpe projection images/yellow to the lf and blue to rt of main
You can fix this in the service menu
Posted on Mar 31, 2009
projdoc
  • 2236 Answers
SOURCE: Shadowing on lower right of screen on InFocus LP70+
the light tunnel (like a square tube of mirrors) is collapsing. it needs to be replaced, but it's a bit involved, so and infocus service center would be your best bet. if you wish to try it yourself, let me know.
Posted on Jul 15, 2009
  • 120 Answers
SOURCE: Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Posted on Jul 23, 2009
Tip
Shadow in the image
If you see a shadow in the lower part of your image when shooting with the built-in flash, it's probably the shadow of your lens hood.
Try removing the lens hood. If that doesn't work, perhaps the lens is too long/big: consult your manual: the manual should tell you which lenses cause shadows. Otherwise, try using a shoe-mount flash or off-camera flash.
on Dec 18, 2009 | Cameras
Canon 1400 IS: When I take a picture using flash of a close up object, a shadow is cast on the lower right corner of the picture. For pictures that are not taken close up with flash, or taken from further...
It's most likely the shadow of the lens. The flash is above and to the left of the lens, so the shadow of the lens will be to the right and below.
Feb 10, 2011 | Cameras
I've had my projector for years now and worked perfectly. But now, there's a shadow on the right side of the screen. I cleaned the lenses and there's still a shadow. With my observations, it looks like...
Remove the bulb, look for any obstructions or damage. If you see none. Replace the bulb, usually replacing the bulb also replaces the lens, the frame around the bulb, and other components all at once making it an easy one stop fix for most visual display problems.
Jun 04, 2010 | InFocus ScreenPlay 4805 Multimedia...
How do I drain the fluid from the radiator on a 1986 shadow 500?
There isn't a drain on the radiator, but there is a drain for the entire cooling system located on the water pump. The water pump is on the lower left side of the engine. Please refer to the image, below.
Dec 04, 2009 | 1986 Honda VT 500 C Shadow
Sometimes I see a shadow when I use my Nikon d-80 flash. In hte lower section of the photo.
Are you using a long lens or a lens hood? Sometimes, this creates a shadow image.
Nov 14, 2009 | Nikon D80 Digital Camera with 18-135mm...
Jul 14, 2009 | InFocus LP70+ Multimedia Projector
Uneven flash
Look carefully at your images taken with flash... on the horizontal image is the lower part of the image slighty darker and have a rounded fall off at the edges? Is the vertical image dark side a straight hard line or is there a rounding to the top and bottom?
What we are looking at is if you have a very wide angle lens with the lens shade attached to the lens, then the built-in flash catches part of the lens shade and make a shadow on your subject... take the lens shade off and try the same shot and see if that makes a difference...
Have a great day...
Ed
Apr 03, 2008 | Nikon D40X Digital SLR Camera Digital...
Shadow on image
The camera has a main mirror that you see with the lens off and a sub-mirror underneath the main one. It may be the sub-mirror is not flipping up completely when you take a picture. It could be off its hinges or damaged. Any good camera repairman in your area should be able to confirm this
Dec 26, 2007 | Nikon D80 Digital Camera with 18-135mm...
108 people viewed this question
k24674
