When my Electric goes, my Htundai pdp 42" Tv won't
SOURCE: Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Posted on Oct 03, 2007
scottyfixit
  • 186 Answers
SOURCE: Hitachi 42HDS69 42 in. Plasma... Problem
Describe the past - How did it fail? One day or acting up for a while? Could be a weak power supply - a bad capacitor on a power supply too. Look for popped up capacitor top inside.
Posted on Apr 29, 2008
jhinsincity
  • 616 Answers
SOURCE: Digistar PH-4210D Black Screen
Plasma tvs do not have "back lights" LCDs do. you probably have a bad driver board along with the upper or lower buffer board or maybe both, best to have a tv shop look at it.
Posted on Aug 30, 2009
budmrtn
  • 11361 Answers
SOURCE: Hi, I have a 37lc46 LG LCD which takes ages to
Replacement power supply is used?
You need to verify the DC output voltages of the power supply first and make sure this power supply has no bad caps with leaking/bulging tops. It goes into standby can also be that it detects fault some where in the set.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 07, 2010
electrotech1
  • 1126 Answers
SOURCE: Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Posted on Sep 14, 2011
Sonicview vpw425 has red and green snow
Hello!
Good question: this problem caused by aged capacitors in Y-sustain module, plus in a power supply. Bad news: if you keep watching TV, it will quit soon with hefty repair bill. So far, all those modules are in repairable condition. Plasma has very high voltage inside and I won't recommend you to even open the set, unless you are have very good technical/electrical background. If so, let me know. I will guide you throughout the repair. If not: pull the power supply board out, then Y-sustain board. Left side of the set with back open. Y-sustain is a quite complicated to remove off the set. Has many fragile connectors to scan converters, plus ribbon cables. Some might be well hidden. If you forget to unplug those, damage will occur. I, personally, won't recommend any amateur or even mediocre electronics technician, to mess with early plasmas. They very well built and packed inside, multiple rubber heat conductors under those boards, etc. Most likely your set has Samsung PDP, because Panasonic PDP, which has been used in Toshiba as well, won't show this problem. It might intermittently loose a picture, but not a "flies" on a picture. I've seen those, in 50" Samsung and their made panels. Guess what: whoever ignored my warning: fix it now or forget it, already got set busted.
I can help you to rebuild those boards, but you need a service manual to safely remove and replace those.
Thanks,
Alex.
Dec 25, 2011 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Dec 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
Cannot program sky remote to operate volume control on pioneer pdp-4270xd pioneer plasma 42". have tried using code 0707 as this is the nearest I can find.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0166
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Nov 28, 2008 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
Plasma TV
Try to open the back cover of your tv and reduce the Vs or Vsc (on Power Supply Board) 5-10V below its spec value. Normally the spec value was printed on the back of PDP panel.
Jan 30, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
