Question about Blodgett (ZEPHAIREG-DOUB) Double Oven
Blodgett oven I am a electrician in Atl Ga. I also fix /repair comm. cooking equipment I replaced a heating element 208 v/230 3 ph. I lost the wiring diagram I drew up to show me the way to rewire the elements they are marked on the back a-b-c which is the the 3 ph. connection but how does it connect to the heating elements thank you m.r.cates
  • brenda238 Aug 18, 2008
    Have a Blodgett gas, double oven, top unit starts up and then shuts back down. Bottom unit will do so in about 5 min. Whats wrong. We have not tried anythng yet.
    Thanks
  • Anonymous Mar 19, 2014
    We have an older model EV-111 which initially will get up to 450, but when trays of Frozen Fries are loaded in to it, it can't climp back up over 350 degrees, even after 20 minutes. Disconnected Power, removed wires from each of the three elements, Measured them each at ~12 Ohms and measured each power lead to be 122 VAC to Gnd. Can an element be bad and still read 12 Ohms? Any details available on how to actually remove the elements? What panels need to be opened up to get at them? This Oven has performed very well for years. Thermostat seems ok because it can be set to any temperature. Red light indicates heaters are on, then shuts off when temp is achieved. Oven maintains temp when empty and doors are shut. Thank you!!
  • 640 Answers
If you only have 3 wires to the element it doesnt matter how there hooked up.
Posted on Aug 11, 2007
  • anthony james
    anthony james Aug 13, 2007
    then you need to hook the element up in series.did you take the unit apart?do you see a jumper wire?
My Creda Reflection double oven keeps tripping the oven fuse when I turn it on? It doesn't trip straight away, it works for a minute or so and then trips the fuse. Any ideas?
call an electrician to check the circuit insulation for shorts
could be vermin cooked across electrical terminals , failing insulation, grease /fat across terminals
dead shorts trip the breaker immediately, ground leakage problems take a little longer
May 07, 2017 | Creda Ovens
How much would it costs to replace heating element on Whirlpool gas oven.
I would not replace the elements just yet it may be ur oven safety valve, u can test the elements with a multi meter for continuity and ohms..
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Jul 15, 2014 | Whirlpool Ovens
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
Eloectric Oven wont heat up either element.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
The bake element
Feb 06, 2014 | Frigidaire Bake Element 316075103
Oven elements don't heat up.
the broil element
The bake element
Smoke comes out of top when cleaning oven. Oven takes way to much time to cook. Oven does not cook evenly. Items cooked in oven are burnt outside and almost raw inside.
hello jjm... these ovens have two heating elements. when one is bad they still heat but they bake way too slowly. this is the problem here. the fix is to replace the bad element but in my repair service I always replace both heating elements since when one goes the other is usually not far behind.
Apr 28, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Element broke, replaced, now oven heats very slowly and only up to 255
This is a symptom of only having 120 VAC power to the oven. When your other element borke it is possible that it tripped only ONE Circuit Breaker. Try resetting the Range CB in the main power panel by physically pushing BOTH breakers to off and then back to on. Then test the range to see if it heats correctly. Let me know the result please.
Also if the problem persists respond with your model number so I can look up a wiring diagram.
Thanks for choosing FixYa,
Kelly
Oct 10, 2010 | Maytag 30 in. Electric Single Wall Oven...
SA999X wont turn off & smells
suspect your electrician wired it up wrong
Feb 20, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Blodgett (ZEPHAIREG-DOUB) Double Oven Logo
481 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
butch welch
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
