Question about Toshiba Satellite M55-S325 Notebook
Wifi switch not working, how to fix or anyway I can get it to work
  • Toshiba Master
  • 5,660 Answers
Suggest replace it
The tools you need are really expensive;
1) No.1 Philips screwdriver, or equivalent Jewelers screwdriver
2) ESD wrist strap. (Electro Static Discharge)
Average cost is $3 to $6.
One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
[The alligator clip has to be attached to a good ground source.
You can set a large serving tray (Unpainted), on the table you\'re working on; and connect to it.
Or perhaps a large metal knickknack. (Unpainted)
You get the picture ]
3) Two computer Spudger Tools. One example,
http://www.amazon.com/Techni-Tool-Spudger-Alignment-Tool-Black/dp/B000PDNPYK
4) Patience. Cost? Priceless
(Kidding about the expensive, thing)
Problem is, I just took time to look all over the internet, and do not see a replacement part.
Nothing listed under Toshiba Satellite M55 wireless switch, or Satellite M55 wireless switch; anyway.
It could be however, that other Model Series of Toshiba Satellites, also use the same wireless switch setup.
M40 or M45, just for an example.
[Toshiba = Manufacturer name
Satellite = Model Series
M55 would equal one of the Model Series Number\'s
The letter, and the last 3 or 4 numbers; is the Model Number.
Example; Toshiba Satellite M55-S1001
Toshiba Satellite M55-S135
Toshiba Satellite M55-S3512]
When you remove the Wireless Switch, then look at the manufacturer number/letters on it.
Type those into search, and see if you can find a Wireless Switch that way.
How to disassemble far enough to access Wireless Switch:
http://www.irisvista.com/tech/laptops/Toshiba_Satellite_M55/laptop_motherboard_1.htm
ALL power removed. AC adapter (Charger), and Battery.
ESD wrist strap on, and alligator clip attached to a good ground source.
The above is to completely disassemble the laptop, and remove the motherboard. You are not EVEN going to go that far.
Only pictorial disassembly guide I had access to give you, that will encompass the procedures needed.
Page 1? Pretty simple straight forward stuff. Feel better? See how easy this is? Just LOOKS tough at first. Hey, it\'s something new!
Now Page 2.
(Page access is by clicking the page numbers in White, at Top of page; and bottom. -> Page1::Page2::Page3::Find another model.
You can click on any photo to enlarge)
A NOTE about the Keyboard Cable, and it\'s respective connector on the motherboard. Also this information may transfer to other cable connectors on the motherboard........
The Keyboard Cable is an FFC. Flat Flex Cable.
It has NO connector on the end. The following is a general example of an FFC,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
The flat bar terminal strips on the end, match up with contact pins in the motherboard connector.
Therefore the Keyboard Cable MUST go back in the same position as it was originally; when reinstalling.
The motherboard connector is a type of ZIF connector.
Zero Insertion Force
It is rectangular in shape, and composed of two pieces; but DOES NOT come completely apart!
The Bottom part is the larger of the two. It stays Stationary to the motherboard.
This is called the BODY.
The Upper part is smaller, and Movable. It is the Locking Bar.
-> IF, the Locking Bar is broken, or the hinge pins on the Body; you are looking at MOTHERBOARD REPLACEMENT, and why I am being so detailed with this.
\'Armed\' with the following information you will do just fine, no worries.......
I cannot see clearly of what type of Keyboard Cable, motherboard connector is being used.
Nope. No Satellite M55 has come through the shop.
So I will detail out the two most common, Keyboard Cable motherboard connectors, being used;
Slide style:
Closed (Locked)
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-10.jpg
Here you can just make out two \'Tabs\', of the Locking Bar; on either side of the Keyboard Cable.
These are EASED up with the thumbnails.
IMHO if a small metal tool is used, there is a chance of slippage.
May break the motherboard connector, or stab the motherboard.
Open (Unlocked)
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-11.jpg
Only moves about 2mm. That is a little more than 1/16th of an Inch, or about the width of this capital letter -> O <-
Flip-Up style:
Closed (Locked)
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
Open (Unlocked)
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
You have to disassemble to Step 19, on Page 3.
Then you should be able to access the Wireless switch.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Apr 30, 2013
    Problem Solver:
  • 4 Answers
You need to update your hardware drivers in device manager.
How do I connect to WiFi on my Apple iPHone 4s?
Try settings - general - reset - reset network settings
Then try to look for available wifi networks again. If that doesn't work check your router has wifi switched on
If that doesn't work it may be that your wifi antenna in the iPhone is faulty
Aug 22, 2014 | Apple iPhone 4S
My Wi-Fi isn't working isn't working, no matter what I try or do it is not getting any access points, what could be the problem?
Boot to F8 then select Last known good configuration. If no fix then boot back to F8 then safe mode then system restore from the time everything was working fine.
If all no fix do the following:
Check if your laptop can see other network aside from your home network.
If your laptop cannot see any network check if the wifi or wireless switch is turned on.
If the wifi or wireless switch is on then uninstall / reinstall the wlan or wifi driver.
May 20, 2011 | Computers & Internet
My toshiba computers wifi won't work but I know that the wifi works because I am on my iPod touch right now and obviously I am connected to my wifi but anyways on my computer it keeps so no Internet...
Mar 30, 2011 | Toshiba Computers & Internet
My Toshiba Satellite L305D-S5940's wifi stopped working
Its posable that the antenna is worn out. Just buy a wifi card and insert it in the slot, they work better anyway!!!
Jul 25, 2010 | Toshiba Satellite L305D-S5940 Notebook
Wireless switch is broken on my acer aspire 3680.
No you need switch,if you use a tiny screw driver you can turn it on with that if its just the plastic peice thats broke.use the screw driver to slide the mechanisam
Oct 04, 2009 | Acer Aspire 3680 Laptop
ASUS wifi switch
Make sure that wifi is enabled in wireless switch utility. You can find that in the system tray next to the clock.
May 28, 2009 | Computers & Internet
Wifi not working
download wifi driver software from www.compaq.com website and install on your pc and on wifi switch on your pc
Apr 18, 2009 | Computers & Internet
My ipod touch wifi wont work
go to settings, then wifi, then it'll show any available network
Mar 22, 2009 | Apple iPod touch
Wifi Not working anymore on 1.1.4 iphone after ziphone unlock.
OKAY WELL APPLE INC HAS STOPPED OTHER CARRIERS TO USE THERE WIFI YOU CAN GET ARRESTED FOR UNLOCKING THE IPHONE THATS THE NEW LAW SORRY THAT I COULD GIVE SUPORT ON YOUR PROBLEM.
FOR ANY MORE INFORMATION PLEASE VISIT US AT APPLE.COM/IPHONE
  1. CHECK FOR IPHONE UPDATES
  2. RESTART PHONE
  3. GO TO SETTINGS AND THEN GENERAL RESET IPHONE
  4. FINALY REACTIVATE THE IPHONE
THANK YOU APPLE GENIUS BAR
May 19, 2008 | Apple iPhone Smartphone
Computers & Internet Logo
111 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
