Question about Garden
Turf til rototiller
What is the pert number for the both drive belts
I need to no the belt size for the v belt on a scott rearline tiiler the model number is 6070s
This is what I found
Forward belt is a 1/2 by 27 (L4270 or 4L270, Oregon 75-427 )
Reverse belt is a 3/8 by 30 (L3300 or Gates FHP 3300)
May 30, 2014 | Ardisam 5.5 Hp Rear Tine Rototiller
I need to know what size belts go on a turf til 5352-51b tiller
phone the dealer or Parts shop they will advise yo on what size it is yo umight have to by some diagrams on the paper to provide you on how to do it from the dealer or the shop
May 19, 2014 | Garden
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
Turf mode not working
turf mode is where only one wheel is powering the sportsman.
sounds like the left wheel is the one that would drive it.
i can not figure out if it is the rear left wheel but it may be. i would see if there is a problem with that.
Apr 04, 2014 | Polaris 2013 Sportsman X2 550
Belt drive diagram for ford rt5
Exploded view of rototiller available at New Holland website.. Area with decals has belt path diagram.
http://partstore.agriculture.newholland.com/us/parts-search.html#epc::mr55011ar111419
Belt goes around motor pulley and tiller pulley and above idler pulley, which is in the middle. When putting belt on, it is easiest to put around motor pulley first and tiller pulley (the large one) last. Belt is 3/8" x 27" v-belt. Idler pulley is available too, only under Lawn Boy part number, which is found on parts list at New Holland site. Just had to perform repair. All parts found on ebay.
Hope this helps!
Rob (Sterling Heights, MI)
Mar 21, 2013 | Garden
Replace belts on Montgomery Ward rear tine rototiller Model number GIL39012B need diagram
Go here and you can download a free manual for your machine.
http://lawnandgarden.manualsonline.com/manuals/mfg/montgomery_ward/tmo39083a.html
Oct 24, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Can I get the specs for belt 727 A? I need to replace this weekend and ARDISAM won't give me a size. Can't afford to overnight. Earthquake Gear Drive 5 HP rototiller. would appreciate help=
DID THE BELT SHRED OR what happened if it is still decent mesure width on top is it a v-shape belt or flat & last thing is cut it & measure it if its still decent that will give you the specs or if theres other # on belt & who its made by
Jun 05, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
We require help with a broken belt on the rototiller
bring the broken belt to napa auto parts or kragen ,,or go to www.managemyhome.com they can tell you where to buy or get it
May 20, 2009 | Garden
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
