Question about RCA D52W19 52" Rear Projection Television
D52w26 film capacitor
The clo31 ,r73 film capacitor blew and the dont make them anymore. it is 0086uf 2000vdc what would work in its place
4 Suggested Answers
toolkits
  • 1099 Answers
SOURCE: rca tv d52w19 shuts-off
hello,
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.
use the same type of value to replace.
Good luck...
Posted on May 25, 2010
SOURCE: rca hd52w59 cp031 capacitor burnt
can't tell you the part number but found a site that sells these caps. Have the same problem and just purchased one.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-box-capacitor-0087uf-2000vdc
Posted on Aug 01, 2010
Slinteriors
  • 8617 Answers
SOURCE: zapping noise on, tv turns
Thats a box capacitor, CL031 . You can get the replacement capacitor from www.tvrepairworld.com its listed under the RCA repair kits.
Posted on May 04, 2011
Not working anymore after I plugged in I have heard some electric noise.
Wild guess but if not powering up, possible that fuse blew (if no external, then there's often one on the power board), or something blew in power supply...check for blown filter capacitors (the larger ones, for leaking, or blown/bulging tops), burnt resistor, or bad diodes.
Aug 28, 2014 | Yamaha HS50M Active Studio Monitor (Pair)
I own a 52" d52w26 hdtv monitor last couple of
I see two possiblites your flyback tranformer has failed and with it your horzital output transitor has shorted. most technicians can replace these. IS the spark in the front or back of tv. if it is in the front this is a tube. as a tech i would first identify what compnents are sparking. also this could be a capacitor shorting cause a burnt curcit board
Nov 02, 2010 | RCA Televison & Video
Rca tv d52w19 shuts-off
hello,
Good luck...
May 25, 2010 | RCA D52W19 52" Rear Projection Television
Ok...I just replaced the .0087uf 2000vdc capacitor that had burned out and the TV came on and worked for about 30 minutes. Now it shuts off and turns itself back on 3 times then it stays off and you cant...
Check for any capacitors that havnt blown but may be very leaky and unable to retain charge, often found surrounding the blown components. Also check the power suply circuitry for any shorted components that may have faulted causing the capacitor to burn out. Good Luck.
Nov 25, 2009 | RCA HD52W59 HDTV Projection Television
The tv turns on and turns right back off.
Yes thats the RCA box capacitor. You can get the replacement at www.tvrepairworld.com its listed under the RCA repair kits category and it has a picture of the Box capacitor.
Aug 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Exact Same Problem. TV turns on, sparks, then shuts off.
your most likely talking about clo31 which is a 0087 2000v box capacitor. You can get the replacement at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-box-capacitor-0087uf-2000vdc/cName/rca-parts
Jul 26, 2009 | RCA D52W23 52" HDTV CRT TV
Rca hd52w59 cp031 capacitor burnt
Dec 13, 2008 | RCA HD52W59 HDTV Projection Television
Electrical zapping noise , tv turns off after starting
can you post a picture of it? It sounds like youre talking about a box capacitor.
Jun 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52w26
Your CRT leaked on the board. You will need to replace the seal as well as the board which got leaked on. Can you post a picture of the board and I will post the board number as well as post a link where you can get another boards at.
Apr 14, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
