Question about Weber-Stephen Products Weber Genesis Series: 3746301 60'' Freestanding Gas Grill with 637 sq. in. Cooking Area, 3 Stainless Steel Burners, Stainless Steel Cooking Grates/Flavorizer Bars, Warming Rack and Electronic Crossover Ignition: Steel Gray Liquid Propane
Manual aquafine dw100
How to change uv lamp
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
www.petco.com/.../Sealand-Replacement-Bulb-for-Green-Killing-...
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
https://www.norlandprod.com/lightsourc.html
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
Dec 10, 2015 | Honeywell Air Purifiers
The screen is turning blue. what is the problem? I just had the bulb replaced a couple of months ago.
Your Optical Block is failing. It needs to be replaced in order to fix this. The details of the mater, if you are interest: The Mercury vapor lamp used in the TV emits UV light. UV light has a short wave length and is therefore positioned on the violet side of the spectrum. Blue, being the closest of the 3 colors (red, green, blue) in wave length, deteriorates faster due to UV damage. UV light damages most things, it is unavoidable. If the UV light was trimmed out by filtration, your picture would be far to dark to view. So, it must remain at some level... even if in time it will destroy the LCD panels (which it does... in every rear projection LCD TV which uses a Mercury Vapor lamp.) As for the fresh lamp... this is common. Your lamp is back up to full UV power and your picture is bright. You can now see the damage progressing more quickly. I hope this was helpful or at least explained the "how and why" for you, best wishes.
Apr 22, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
I replaced the lamp. now I have discoloration, Red on top and blue on the bottom
Your TV is an LCD rear projection type which requires a Mercury Vapor lamp. Mercury Vapor lamps emit UV light which is damaging to many materials. The discoloration you are seeing on the screen is the UV damage that has resulted over time to the LCD panels within the “Optical Block” (aka projector) of the TV. This discoloration has been creeping up on you for sometime, it just wasn’t as noticeable until you changed the lamp. Once you installed the new lamp, the UV light is bad at full force and the damage progresses at a quicker pace, due to the already weakened state of the LCD panels. Additionally, the picture is now brighter, exposing the damage for you to clearly see. The only fix for this problem is to replaced the Optical Block… an expensive repair. Although this is not good news, I hope this helps you understand the cause & solution and was of some assistance.
Mar 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a "fresh air" and I'm receiving a message saying synair- G4 replace lamp. Does this mean only to replace UV lamp
This means that the UV lamp has stopped working. Since you need a good starter to make the lamp work, it make sense to replace both at the same time.
Feb 04, 2010 | Ecoquest Fresh Air Air Purifier
I need an instruction manual for a DeWalt DW100 bandsaw.
Hi I have a manual for DW100 bandsaw. E-Mail : mikepat21@sky.com and I will send a copy to you. Regards Mike
Sep 06, 2009 | Dewalt Saws
Dewalt DW100 with no instructions!
Go to Dewaltservicenet.com and in the middle of the page at the bottom you will see a box for manuals, type in your model number and it will bring up a list of tools with that number, you might have to click on a couple but I did see a manual for the DW100 that can be downloaded. Let me know if you still have problems
Mar 23, 2009 | Dewalt Saws
Pure ion uv light does not turn on
Where can I get a replacement ultraviolet germicidal lamp? I have been to Brookstone store and on line without help. My unit is a Pure Ion.
Thank you.
Dec 25, 2007 | Brookstone Pure-Ion UV Air Purifier
Ecoquest air purifier uv lamp replacement
If you haven't done so, try replacing the lamp starter.
Sep 29, 2007 | Ecoquest Fresh Air Air Purifier
Weber-Stephen Products Weber Genesis Series: 3746301 60'' Freestanding Gas Grill with 637 sq. in. Cooking Area, 3 Stainless Steel Burners, Stainless Steel Cooking Grates/Flavorizer Bars, Warming Rack and Electronic Crossover Ignition: Steel Gray Liquid Propane Logo
79 people viewed this question
Top Weber-Stephen Products Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Weber-Stephen Products Grilling Expert? Answer questions, earn points and help others
