Question about Ricoh Aficio SP C242DN Laser Printer
What does code sc542 mean
Code SC542, what does this mean?
    Sergeant:
  • 148 Answers
This is an error for the fuser heat up..the temp is not being maintained or fluctuations.
try this -
press the yellow clear button at top of number pad then enter 107 and hold down the red cancel button..the screen will change
enter the copier sp and select 5.mode arrow down to 5-810 sc reset and execute.
turn machine off..
if the code disappears it could have been just a glitch
if not check the fuser to see if there is heat coming from it
the lamps will come on at the start up.
you can check this by putting a screw driver in the actuator slot to cheat the door switch
if you see the lamp come on then you may just have to clean off the thermistors ..
open the fuser up with the top screws and check that there isn't any build up of toner on thermistors..
Posted on Apr 13, 2015
  • 4 Answers
It's fusing termistor error change it
Posted on Aug 17, 2014
4 Suggested Answers
blueydfox
  • 13 Answers
SOURCE: Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Posted on Apr 29, 2008
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Now when i put my photocopy machine on the SC542 code error appears So i need a solution for this problem
Hi rfofie,
There's no specific brand or model you have mentioned on the issue that you needed help. However, I can provide you the meaning of the error code that you are getting. The SC542 error code is a Fuser Temperature Error. That means that the fuser did not warm up fast enough. You will have to replace the fuser to get rid off the error.
Hope it helps.
Thank you for using Fixya.
Mar 29, 2011 | Office Equipment & Supplies
Gestetner 2212 copier Service Code SC542 I"ve
In your machine (model) you have to enter in SP mode to reset your error code.
Try this:
Yellow key.
1-0-7 on the key pad
Red key at least 3 sec.
Press "copy sp"
On the key pad press 5 810 and #.
Press execute
Exit all the way out.
Turn the machine off and on.
Feb 28, 2011 | Gestetner 2212 Digital Imaging System...
SC542 error code
Without a model, I can't give you a lot of information, but I am assuming it is a Ricoh machine (Possibly Lanier/Gestetner, same difference), as that's the format of their error codes. An SC542 error code is a Fuser Temperature Error, meaning that the fuser didn't warm up fast enough. It is extremely likely that you will have to replace the fuser unit before the error code will go away. Please give me a model number if you need more information and I will try to be a bit more precise with the information. Thanks.
Feb 28, 2011 | Office Equipment & Supplies
We had power failure today and now after unplugging it and just turning the power off our Ricoh still has SC542 as an error code- - please let us know as to what we should do- should we try something else...
You should have a service technician come look at the machine. sc542 is a fuser code, which could mean that a thermostat was blown, or it could be a dirty or defective thermistor. A Ricoh technician will be able to inspect the fuser and make that determination, and hopefully get you up and running right away!
Jul 06, 2010 | Ricoh Aficio 2015 Copier
Errore sc542
Error SC542 indicates a fuser temperature problem.
you must perform procedure 5810.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
The error code is now cleared.
Good Luck!
May 07, 2010 | Ricoh Aficio 1085 Laser Printer
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press Enter
  • Press Enter
  • Press Enter
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
Ricoh Aficio SP C242DN Laser Printer Logo
191 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
