Question about Riso RP 3700
Hi: RP 3700 reads "System Error A17-221 Rewind Master Roll and close scanner table"I have done all the above and keep getting same code.Solution?Thanks,Pat...
    New Friend:
  • 58 Answers
Check the master disposal system and box for jammed masters.
Posted on Feb 14, 2014
3 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: Riso RP 3700 indicates that the master is still on
It honestly sounds like the unit is going to need some repair work. All the types of troubleshooting possible have been done by the looks of it. It's a hardware problem which is impossible to repair remotely.
You can call Riso at 978-777-7377 to find the nearest service center.
Sorry about that.
Thanks for your patience and understanding,
Tim
Posted on Aug 12, 2009
fivemayur
  • 414 Answers
SOURCE: Error A-01-211. Master roll not feeding properly.
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
OR replace it
Posted on Feb 26, 2013
Riso RP3700 gives A17221 error msg
have you checked you master disposal unit if there were any masters jammed in it?
Jan 29, 2014 | Riso RP 3700
Riso RP 3700 T12-305
t12-305 The master compression sensor does not go ON within 6.5 s after the master compression motor operates in the return direction.
kindly try to check your master roll and respool it. the problem could also be because your master cannot be dispose the old master properly. remove the old master and respool your master roll and initiate your machine or turn it of and turn it on again. hope to be of help.
Dec 27, 2013 | Riso RP 3700
Riso EZ 200E model gives error message A-01 -211
A-01-211 basically means there is master material under the position sensor while in standby. Referring to the manual open the master drawer and clamp rewind the master material back on it roll and close the lid/clamp. This allows the master unit to reset or to say "return home" action. Now open and re-insert the master material in its proper place. This is similar to A-34-218 code.
Nov 07, 2013 | Riso RZ220 Duplicator
System error T01-521
Error type T01 [Main-motor lock]
T01-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset
Error point Error conditions
520
The main motor limit sensor does not go ON/OFF for more than 16 pulses while
the main motor is operating, even after the elapse of 100 ms.
521
The position-A sensor does not go ON/OFF, between two detections of position-B,
while the main motor is operating.
522
The position-B sensor does not go ON/OFF while the motor is operating, even
when 3033 pulses are received at the Main FG.
524
The clamp unit is not at the home position while the print drum is operating
(Clamp sensor C: OFF, except during master disposal).
536 The drum failed to stop at position A. (over-run)
537 The drum failed to stop at position B. (over-run)
538
The print
Sep 24, 2013 | Riso RP 3700
mon riso RP 3100 ep donne le code to1-521. veuillez me trouver une solution merci
Nov 22, 2012 | Riso RP 3700
White stripes on copies
Looks like some dots of the thermal head are defective. So the master at these dots cannot be punched.
Sep 28, 2012 | Riso RP 3700
Error code A-01 -201
Which model of Risograph?
Error type A01: Master mis-feedError point 201: Master-positioning sensor does not go to ON even after the write pulse motor is activated durcing the paster-positioning, master cut, or master-loading operation.
Try this:1) Pull out mastermaking unit and rewind master roll, then re-set master in place.2) Check write pulse motor and its gear
Sep 18, 2012 | Riso Office Equipment & Supplies
On riso pr 3700 can not get the full image on landscape mode when I make a master
Maybe you meant model RP3700 ...
These questions may help to find a solution or at least a better understanding of your problem:
Have you set the paper size right?
Is the print drum capable of the desired imaging size?
Mar 31, 2010 | Riso RZ390 Duplicator
Riso RP 3700 indicates that the master is still on the drum halfway throught the master making process and shuts down. The master has been removed. shutting down the machine does not help. Rolling on a new...
Remove the roller on which the master has been created. That will force the machine to start a new cycle. Right now the machine has thinks its in between the cycle, so to synchronise both, its been told to remove the master. Switch it off & then begin again........sodeep
Aug 10, 2009 | Riso RZ220 Duplicator
Riso RP 3700 Logo
257 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
