Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD64, leaking water from soap drawer
The above problem has continued even after checking for blockages at the black rubber pipe that connects the soap drawer to the drum area. I have also checked the sump drain pipe??, black in colour below the drum, that holds the filter. Even after emtying the filter the machine still leaks a lot of water on initial fill. After that it seems to be ok. Soap drawer area is clean and soap free except for the stuff going into the machine. Anyone got any ideas. Thanks Alan
  • 2 more comments
  • Anonymous Mar 02, 2008
    Hotpoint WD64 washer dryer. On initial swithch on and fill, water sprays in to the soap tray but then slowly seeps down the front of the machine (at first glance I thought the door was leaking). There don't appear to be any blockages and I think our high water pressure may have something to do with it. The spray is maybe too powerful and simply sprays into the soap dish then out of the soap door?
  • Anonymous Aug 27, 2008
    water leaking out of the soap drawer on initial fill up is hot
  • royb01 Dec 02, 2008
    I've the same problem as above, I've checked the obvious stuff, blockages, filters, pipework etc and everything is fine.
    It looks like too much pressure (cold fill?) but this problem has only recently occurred and used to be OK.
    The comments on the condenser are interesting but why would this cause this problem?
    Appreciate any feedback.
    Thanks
  • Anonymous Mar 23, 2014
    leaks intermittently when filling. Has been checked for blockage but none found
  • 67 Answers
Your condenser is blocked,you might be lucky and get away with just cleaning it, but most of the time it is just best to change it. You will have to take the back off again it is the plastic component with the fan motor attached, disconnect the 2 black tubes to it [note where they come from] unscrew the 3 bolts at the bottom , disconnect the wires going to the fan motor. If you are going to change the condensor you will have to take the fan motor off aswell MAKE SURE YOU DISCONNECT THE MACHINE FROM THE MAINS. GOOD LUCK
Posted on Aug 07, 2007
Just gave the condenser a major overhaul, a bit tricky to remove but sorted. What is interesting is that the small 'vent' tube from the detergent box was blocked with fibres etc in the condenser housing, it is now clear and it seems to have resolved the problem.
I have the main water pressure back to 100% now, technically unsure whether this was causing a airlock causing the water level to rise in the tray etc, Ant thoughts?
Fingers crossed!
Roy
Posted on Dec 02, 2008
  • 30 Answers
Try turning down your cold water pressure. some times the pressure it is so great that the water hits the soap dispense and spill over. this is a common problem with front loaders??
Posted on Aug 15, 2007
SOURCE:
When machine spins after wash water gushes out of detergent drawer. Checked black hose from drum and found a blockage of colour catcher sheet thought this was the problem but water is still gushing out the...
Hi.
The problem can be a defective pressure switch. The pressure switch detects water level. Pressure switch not working correctly may result in overfill. Try cleaning the rubber hose connected to the pressure switch. Check also pressure from inlet hose and look for blockage in detergent drawer.
Aug 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Water leaking from soap drawer all over the floor during rinse cycle (I think)
probably find a blockage at back of drawer, check the small pipe in the drawer, and unblock this should solve problem
Dec 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Water is leaking from soap dispenser only at beginning of cycle
Remove dispenser drawer, and check for soap blockage.
Locate and clean filter, check to see if there is one located behind bottom kick strip, if no filter there, then you will have to remove lower rear cover of washer, and locate and remove the large black hose on bottom of tub.
Remove filter and plastic ball,clean and replace.
Refit filter, ball and hose ,ensuring it is fitted correctly.
Test for leaks.
Plz ratev my solution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WD440 Drawer overflowing
Hi.
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Thanks.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machines is leaking from the front at the bottom
if the hoses & pump are not at fault, the water may be running down from the soap drawer inside the machine & dripping from above
Oct 21, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF 240 Front loader
first remove the soap drawer, this should expose locating holes for screws, remove these first, then remove the screws from on top of the plastic front panel and then the plastic front panel tilts forward to remove, taking extra care with wires etc the soap drawer is now loose still attached to the rubber pipe, which is now easy to get to for inspection, or removal to clear it out. first of all just check that the machine drum is not filling up totally so it is overflowing back out of the soap drawer, if so that is a different fault entirely and does not need taking to bits the same
Sep 21, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Soap dispenser slow leak
Plug off the wall socket first. Remove screws to remove the top of your machine. Check to see if the rubber hoses are connected well to the dispenser chamber, if not connect them properly. Another thing could be your dispenser drawer; you could pull it out gently to clean it; or you could even use a tooth brush for access.
Sep 20, 2007 | LG WD-1080FD Front Load Washer
Our Washer is overflowing through the dispenser drawer
water out of the soap drawer could be a multitude of things, start with removing the drawer and checking for blockage in the pipe from the drawer to the drum, next try turning down the water pressure a little sometimes that can help, or has the machine filled up totally till it overflows, that is a blocked pressure switch pipe, start with looking for the blockage first, work with safety unplug if removing lid etc. rate me if i have helped, thank you
Sep 16, 2007 | Maytag Neptune MAH9700 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
779 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
