Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
How to replace a clutch in a 3000 ford tractor
I have a ford 3000 tractor that when you put it in gear and let the clutch out it wont move but if you press the rear differentil lock pedal it will go
You either have one of your rear axles spline stripped or broke, or side diff gear. The diff lock will lock both axles together and pull it self stripped or not. The diff lock will make tractor pull itself but only one wheel is pulling the tractor at this time. Determine which wheel is pulling and which one is not with diff lock on. The one not pulling is the broken side. Disassemble and repair.
Jan 05, 2017 | Ford Garden
How to adjust free travel on ford tractor 2000 clutch
Where the clutch fork enters the gearbox there should be a rod with a lock nut on it give it about 1/4" free travel.
Oct 19, 2014 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Ford 2000 tractor
Yes you blew the clutch. Never let a tractor coast with just the clutch engaged, the only safe way is to place the transmission in netural.
Aug 29, 2014 | RTO Ford Tractor 2000 3000 4000 5000 Water...
2n ford tractor stalls when i let the clutch out
Your clutch needs adjusted a little more. Not releasing all the way.
Dec 28, 2012 | Ford 8n,9n,2n, Tractor Starter With Drive
YTS 3000 clutch return spring noise, sounds like it is rubbing on something when you release the clutch but I can't even find the spring
The spring will be attached to the tensioner pully right on top, there is a threaded bolt with nut holding the spring on, I just had to order the clutch cable because the spring broke, from rubbing on metal when engaging and disengaging the clutch lever.
Jul 30, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Clutch just stopped disengauging. I have been driving this tractor with no troubles for the past month, when depressed the clutch pedel has always disengauged the clutch, but today, I pushed down on...
i have a 8 n ford tractor it want stop when you push the clutch down clutch feel good so i split the tractor and the clutch looks pretty good can you help me
Sep 26, 2009 | Ford Tractor Naa Golden Jubilee Emblem
My PTO will not engage without grinding but works great once engaged, Model is only shown on the engine as C10 with production code of 5F5B and serial A281771
when u engage u have to push in clutch and wait for spinning gears to stop the engage pto and let out clutch, excessive spinning of gears can be caused by low transmission grease also causing grinding
Apr 13, 2009 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
