Question about IBM ThinkPad A20 2628 Notebook
Help! hi, ive recently purchased a a20 thinkpad, ive upgraged it to windows xp with no problems, but im trying to connect it to virgin broadband, but it comes up with an error saying: broadbamd setup cd could not renew the IP address for your network adapter (DHCP. does anyone know how to solve this? thanks, Laura
    President:
  • 2,961 Answers
Go to start>run, then type ipconfig /flushdns and press enter. If no luck then go to control panel>network connections, then click on your network adapter sometimes called local area connection unless it's wireless and right click>properties, click on the tcp/ip line and click properties and check the obtain ip address is ticked and select ok. Try again and if that doesnt work go back to network connections, right click on your network connection and select uninstal, then restart the notebook and it will reinstall itself for you to try again.
Posted on Aug 07, 2007
SOURCE:
Hi ive recently got a zyxel p660 router on eircom broadband,the ethernet cable works fine with my laptop but the wireless doesnt,when i go into my connections it says im connected and the signal is...
Go to "My Network Places" and then click on "View Network connections". You should see an icon for your internet service provider. If you do not see an icon to your ISP, then click on "Create a new Connection" and follow the wizard which will guide you through the setup process.
Apr 02, 2011 | Computers & Internet
Hi there, i have a powershot a20 and am having trouble connecting it to my windows xp pc.
You may have a compatability problem. Try this link or
run help and support and search 'compatability', then look
for your product in the catalog.
http://www.microsoft.com/windows/catalog/default.aspx?
subid=22&xslt=experiencecategory&pgn=e16026b4-03c5-42e5-
bd63-a79b829f7968&groupid=603cda5f-d381-4e04-8966-
167eea110173
Mar 11, 2011 | Canon PowerShot A20 Digital Camera
Laptop Virgin?
you can download the manuals for the NB from the following link
www.hp.com/support
enter the product number of your NB, then in the search bar type manuals. It will take you to the manuals page.
You will have everything you want..pictures.. initial setup screens, specifications etc..
For wireless internet there is a switch in the NB that need to be turned on. It looks like a tower and sound waves coming out. After you do that you need to have a router and a dsl / cable broadband internet connection to be able to connect to the wireless internet
Regards,
Anup
Apr 06, 2009 | HP Compaq nc6000 Notebook
I can't install XP on Thinkpad A20P #2629
im sorry to say this laptop is just not fast enuf to run windows XP you best bet for this would be to run windows 98 or a distro of linux that fits your needs  there are no bios updates at this time that will allow you to install XP on this system. sorry
Mar 27, 2009 | IBM ThinkPad A20 2629 Notebook
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
I have recently moved house from a virgin broadband connection taking my router and lap top with me. My new home has existing virgin broadband. Having plugged everything in as should be my laptop finds the...
Try reseating te broadband connection to the router.
It soundslike your router works if it connects to your laptop with a great signal. But its not sending any information through.
Try reseating. if it does not work. you might need to do a fresh reinstall of the router. Usually the broadband connections attach itself to a mac address of a network card. If you recently put a new router the network cards MAC address is different and it might not send signals through. like for me for cable i have the same issue.
Try this let me know how it does. If any problems please let me know.
I hope this helps
Please Rate.
Sep 18, 2008 | Belkin Computers & Internet
I recently moved house and got virgin media to install phone tv and broadband. Connected the modem through Ethernet. Worked fine....then the PC froze and when I restarted, start up message was "PORT...
That's fantastic, but other than blaming either Virgin or your new house for the PC problem, not terribly instructive.  What's this about a modem...you mean you connected your PC to Virgin's cablemodem using cat5 ethernet, which is pretty normal?
  Give exacting circumstances (e.g. timing after the BIOS and Windows screens came up) and descriptions of the error messages, and people can help out, especially if you go create a new problem under your exact PC model, and try to suss out the problem by googling for 'Port 00 error' and your model.
As it is it sounds like Windows found bits of itself missing (as moving vans can cause sectors to go bad on HDs) and vainly hoped you would have the Windows 98 or XP install CD handy to fix things.  It is probably time to install a new hard drive and appropriate OS of your choice, and copy info over from the old drive before labeling and packing that thing for spare use.
Aug 01, 2008 | Computers & Internet
Modem connection problems
The DNS failing is because of your Broadband provider. When you purchased their internet, they were supposed to supply you with a modem. If they arent helping you with this, they are scamming you of your money and you need to go with a new provider. The DNS has nothing to do with what you do or what you can do. (Nothing you will do will controll this except for contacting an internet service provider.)
Apr 02, 2008 | NetGear DG834G Router
IBM ThinkPad A20 2628 Notebook Logo
121 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
