Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
How to adjust generator voltage? Currently it is 150 V line-gnd.
Model 030424. I suspect it is the engine idle. Can't find any documentation on where the adjustment screw is and how to adjust it.
    Problem Solver:
  • 16 Answers
Go to B&S web site or peach tree.com with your engine number you can look up picture of the engine an fine where to adjust it
Posted on Dec 12, 2013
5 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: I need to adjust the
It is always good to have the voltage set down by a small percentage and so the setting you have is quite good because most devices work happily with a lesser voltage than a higher one except those consuming higher currrent.
Now if you set the generator for the higher rating with the connected load and when the device is not used the voltage will rise above and may damage sensitive equipments. So take this tip.
Posted on Sep 25, 2010
  • 185 Answers
SOURCE: I have a Briggs and Stratton 5500 watt Generator
Hello, I would not advise you to adjust the speed without a frequency meter. for 220 volt operation, you will have to use the twist - lock receptacles and not use the neutral in the receptacle. This means one of the generator's hot leads is going to be the neutral in your system. The frame of the generator may be connected to the neutral of the generator, so be careful so that you do not receive an electrical shock. The voltage is adjusted within the receptacle box. There might be a small hole on the right side of the receptacle box that you can insert a small blade screwdriver into to make the voltage adjustment. You do not need to change this much to change the voltage. Now, the frequency is adjusted by a self-locking nut located under the air cleaner right side, when facing the engine. There is a spring on this nut / bolt assembly. I think it is a 5/16 nutdriver or socket that you need for this. Turn counter clockwise 1/8 of a turn. This will slow down the generator to about 50 - 55 hz. This is okay if you are running at around 52 hz. As the generator loads, the rpm will drop down. A frequency meter would be great to use here, as a too low rpm could burn out electrical motors and other equipment that you are using. Feel free to contact me joeleier@gmail.com www.freelancemissions.com
Posted on Jan 22, 2011
Testimonial: "Thank you for the quick response. Great advice and outstanding instructions."
  • 1383 Answers
SOURCE: I have a Briggs &
Depending on the engine, you will find an arm attached to a small shaft coming out of the engine block. This governor arm is where there is attached a governor spring and the linkage going to the carb. The governor spring is attached to the arm on one end and to either a bolt or a tab of metal on the other end. If attached to a bolt, you will find a lock nut and enables you to increase tension on the spring (pull harder) thus increasing engine speed. If you have a metal tab, by bending the tab away from the spring, you will be applying more tension. You will not be bending carb linkage. Before you make any changes, find a meter that can measure Hz . Plug the meter into house plug and notice that hz reading will be 60 cycles. Then read voltage at house plug, could be 115 thru 120 or higher. Your generator produces 60 cycles when it turns 3600 rpm. Before you make any adjustments, plug meter into outlet and check hz. If reading is at 60hz, the engine is already running at max indicating problem with actual generator parts and not engine running slow. If cycles low, adjust by bending tab pulling harder on the gov. spring, or adjust screw to pull on he spring. In either case, adjust a little and re-test. With engine running to produce 60 cycles, the voltage should be between 115 thru 120. Some generators have an adjustment screw to increase voltage on the voltage regulator inside the gen set. Look for Good luck
Posted on Sep 01, 2011
SOURCE: frequency adjustment or solution
Can you check the RPM of the engine? 3600 RPM = 60 HZ. If it is running around that speed, try a different frequency meter.
If it was producing 180 HZ, it should automatically shut down and show a fault code!
Posted on Dec 16, 2011
Mga bosing ask ko lang po kung ano problem ng suzuki raider 150 ko bigla nalang namamatay in high speed or low speed marami na po kasi ako napalitan sensor carburator spark plug
Hi, Norlan the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. The gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
Loss Of Power Troubleshooting Bogging Down BuggyDepot com 150cc...
http://www.singaporebikes.com/forums/archive/index.php/t-119629-p-3.html
Why is the engine bogging under acceleration Suzuki FA50 Moped
Suzuki Raider 150 FU150SC Owner Manual
http://mototh.com/files/suzuki/Raider-150R/Suzuki-Raider-150R-parts.pdf
Apr 25, 2016 | Suzuki Motorcycles
I have pulsar 150 bike.....2015 model.....the bike running few kilometer..suddenly off the bike when running...bt petrol is fuel...what is the problem???
Hi, Mithun the following applies to carbureted also fuel injected models and the usual suspects are:
9. Air/fuel mixture ***** improperly adjusted.
13. Gas cap is not venting properly or fuel tank venting system blocked.
How to Tune Engine of Pulsar
http://www.xbhp.com/talkies/help-me/22173-pulsar-150-sudden-serious-issues-help-needed.html
just bought new bike Bajaj Pulsar 150 this month have been riding other...
http://www.bcmtouring.com/imp/Pulsar_DTSi_Workshop_Manual.pdf
Bajaj Pulsar 150 DTS User Manual
Apr 12, 2016 | Motorcycles
The engine starts on my benelli motorella 1965 model and then cuts out
Hi, Anonymous the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or a damaged battery, 9 volts or lower.
2. Faulty alternator/generator and or voltage regulator.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, O2, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Water or dirt in the fuel system, carburetor or filter.
9. . Restricted, blocked or kinked fuel line.
10. Fuel tank empty.
11. The gas cap is not venting properly or fuel tank venting system blocked.
12. A faulty Fuel Pump, pressure regulator and or fuel injectors.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
For more information about your issue, please visit the websites below.com. Good luck and have nice a day.
Chinese scooter won continue to run
HELP scooter wont stay running clean carb
How to tune carburetor in GY6 chinese scooter 150 or 50 cc
Scooter Carburetor Idle Adjust
Classic Motorcycles
Nov 17, 2012 | Benelli Motorcycles
Scootor runs about 2 to 5 minutes then dies out shuts off
Hi, Bill the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or damaged battery, 9 volts or lower.
For more information about your issue and free downloads that you need please visit the websites below. Good luck and have a nice day.
CF Moto 150 Sudden loss of power
CF Moto Scooter Question
http://absolutelyscooters.net/service-manuals.html
CF250 Water cooled parts
http://www.cfmoto.cn/download/?cateId=1&Id=16
Jun 01, 2012 | 2007 C_F Moto 150 EJewel AutoMatic 150T
Throttle on generator question
The idle control switch allows the generator to go into idle when there is no demand form the appliances connected. This saves gas and increases the life of the generator. Damage can occur for some appliances like a refrigerator/freezer because the voltage and frequency are not prepared for the load resulting in a low voltage bad startup that will damage the appliance. Suggest that you leave the idle control switch off while any motor/electronic devices are connected.
The throttle control is likely a choke function for starting. These generators are designed for only one running speed to produce the necessary 60 cycles per second and voltage.
The following link is to a Canadian web site that later in the detail report describes the concern of idle control. In addition it provides good insight to the operation and use of portable generators
Hope this helps?
Understanding Portable Generators
The user manual see pages:
http://www.mikestools.com/download/Porter-Cable-Manuals/Porter-Cable-CTE300.pdf
May 06, 2017 | Porter Cable Portable Generator BSV750
AC voltage is 275vac on the powermate generator model # PM069250......engine speed is 3750 rpm (max is 3600 rpm)......how do i lower the speed and the 275vac to a nominal 240vac output.There is no expert...
On the engines carb. is a governor rod should connect to the front case of the engine. This rod should have an adjustment to slow the engine speed. BUT,,, are you reading the generator unloaded or without any thing plunged into it? Once you have the generator loaded with a device, the voltage should drop to a constant 240vac. 150 rpms should not make that big a difference on the voltage output, and if running under load the RPM's should drop also..
Sep 04, 2011 | Acabion Helix Motorcycles
Hi, I have a derbi mulhacen 659 model 2011. When I drive the motor, after a while the motor turns off.. When waiting for trafficlights...it's shuts down .... expecially when the motor is warm, engine...
Hi, Quest25 the following applies to carbureted also fuel injected models and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you need please visit the websites below. Good luck and have a nice day.
http://www.her-motorcycle.com/stalling-at-a-traffic-light-or-stop.html
Stalling Shifting and other Noobness
https://answers.yahoo.com/question/index?qid=20110902151558AAV6IRD
Motor stalls when idles hot in traffic
Aug 20, 2011 | 2011 Derbi Mulhacen 659
I have a 2005 Diamo 150 scooter. It always starts when the engine is cool but it sometimes stops or fails to start when it is warmed up. What is the problem with my scooter?
Hi, Jerry the following applies to carbureted also fuel injected models and the usual suspects are:
http://www.apriliaforum.com/forums/showthread.php?174841-My-scoot-won-t-start-sometimes-when-engine-is-warm
scooter wont start when hot
http://www.carlsalter.com/diamo-service-manuals.asp
Scooter Parts for Chinese Scooters Atvs
Chinese ATV Owners Repair Manuals
May 24, 2011 | 2007 Diamo Tracer 150
Voltage is high around 150 volts. I reduced the
The speed will change the 'frequency' too. You need to make sure you still have 60 Hz. You may have need a voltage regulator adjustment, not a speed adjustment.
Aug 01, 2009 | Coleman Powermate Powermate 5000W...
Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Apr 12, 2009 | Guardian Electrical Supplies
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
308 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
