Question about NRG Furniture
One of the support wood pieces, is stripped. How cane this be taken care of?
    Problem Solver:
  • 11 Answers
Remove the screw. cut a few slivers of wood with a knife or just use toothpicks. put wood glue in hole and push wood slivers in hole. break them off at the end or just take a hammer and tap until flat. let glue dry then drive your screw.
Posted on Jul 02, 2013
What disolves a glue strip for wood transoms?
There is a great product out there called "Goof Off." Be sure to do a test in an area that wont be noticed to make sure it's safe on the surface you're working with.
When you are done be sure to use a damp cloth to remove the fluid and wipe dry immediately.
Depending upon the surface you could also try a piece of cotton fabric and a hot iron. IF the glue is on a smooth surface it should transfer to the cloth. Be careful and don't heat the surface too much.
May 19, 2017 | Crafts & Hobbies
Installation in a hole bigger than the unit, is there a flange kit or something that will help get it to fit?
yes there is a kit you can use. most diy shops that sell cooker fixings etc will have them. they usually stainless steel and you have to cut them to size you need. and make a square with it. backing with bits of wood to the size of the hole need to put the top on and the stainless steel to cover the wood that has been put in. you can make your own. by filling the hole with wood strips get from a timber yard or store have them cut the size you need. then fix them to the open part you need to fill. leave a lip ( this is to put the stainless steel to. check it all fits. then get the strips of metal to fill the hole making sure they the right size glue them down to the strips of wood you have put in then put the top on. jobs a good one. don't nail the wood in place put 4 good long screws in each piece of wood gives it strength then.
Oct 30, 2013 | GE 30 in. JP340 Electric Cooktop
We have a Back To Basics popcorn popper that has a broken piece. The piece is the clear see-through plastic top. Where can we find a new piece?
West Bend took over this company and no longer provides plastic window replacements. I fixed mine by super gluing the window and attaching a small strip of wood on top of the 2 plastic window pieces with small bolts (super glue pieces so wood can be properly attached because glue alone will not hold up to the heat). Not attractive but it works. (West Bend rep told me windows break because of high heat, but I only used mine over medium heat; I think they break at the spot where the raised lid hits the gear mechanism holder.)
Dec 11, 2011 | Back to Basics Popcorn Popper (PC6)...
FILLS UP, DOES NOT SPIN, BUT TRIES WITH CLICKING
master gearbox is stripped a cog it will need to be repaired in most gear box cases the cost outways the replacment of a new washer
sorry
take care
Feb 15, 2011 | Washing Machines
How do I lock the motor in to remove bolt and replace blade
If there is not a built in lock for the motor simply use a scrap piece of wood. Pull back the blade guard and place the saw on the piece of wood with the teeth logged into the wood. Apply pressure downward on the teeth and remove the bolt holding the blade in place. You can also use a scrap piece of wood to wedge in the saw between the guard and the blade to prevent it from turning. Be careful and make sure you are turning the bolt in the correct direction.
Apr 16, 2010 | Skil 5500 01 7 1/4" 120V Circular Saw Kit...
I just applied wood-filler to cover the screws in a project I'm making. The wood is already finished using lacquer, so I can't sand off the excess wood-filler when it dries. What can I use to smooth it...
I would use a utility knife blade out of the knife at a 45 degree angle. You will get 99% of it removed. If you work hard enough ay it you can get it all.
Apr 15, 2010 | Garden
Bathtub installation
Now I see the wood stud is added support and the tub should rest on it. though it is not to hold the tub up. Like a man using a cane the cane doesn't keep a man standing by itself. Rather it helps a person be more stable that's what the stud does. Set at height for a level tub.
Here is a trick as well for supporting the back of the tub (Shimming) Get some of the expandable foam. Set everything in place like the wood ledge when you have everything in place and tub pre-fitted. Remove tub and place a line of foam along back side. Place tub in place and when foam expands and dries it will become your perfect shim. Hope this helps, thanks for using FIXYA. Good luck, Jeff
Apr 08, 2010 | Maax Home
To remove radio on a 1998 Buick LeSabre describes removing a plastic wood strip in middle of dash. It does not however, explain how to remove this trim strip.
I have a 1995 and 1999 LeSabre and the radio removal is the same on both.
1. Carefully remove the AC vents from the dash.
2. In each of the AC openings are screws that hold the top of the dash trim in place.
3. Starting from the passenger door gently pry off the "wood" trim piece, It is held in place with metal clips and velcro.
4. Do the same as 3 from the driver side (short piece).
5. Remove the remaing screws from the bottem of the dash.
6. Move the Shift knob (requires key) all the way down.
7. Starting at each end of the dash slowly pry/pull each clip along the top of the dash from its mounting hole. Be careful not to crack the silver trim piece on the top of the dash (especially on top of the passenger airbag).
8. When the dash is free tilt the top in towards the car and wiggle it loose around the bottom (over the steering column) and the whole piece should come free.
This gives access to the radio, heater controls, speedo etc.
For the radio - three screws - antenna cable pop out. The harness needs a little more work. If your radio has a security feature (blinking light when car is off) make sure you know the security unlock code. Test the code before pulling the power to the radio.
Turn the radio over and carefully unlock the blue clip at the bottom of the plug. Then work the harness loose.
This sounds much worse than it is - it should take 15-30 minutes depending if you have all the tools close by. BTW those AC vents have a top and bottom - the larger hole goes on the bottom and they snap back in place.
Jul 03, 2009 | 1997 Buick LeSabre
Top roller stripped off rubber when had a jam
If you have just taken delivery, it must still be under waranty. The roller can get stripped so soon. Shld return it to supplier.
May 23, 2009 | Xerox DocuColor 12 Printer
Handle has pulled away from the door. How can I access the screws
Realized the top chrome part split into 2 pieces and then was able to remove the wood like strip in the chrome strip. Popped the top chrome anchor, reattached the handle bracket as the screw holes were not stripped, put the wood like strip back in place and slid the top chrome anchor back in place.
Feb 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Furniture Logo
351 people viewed this question
Top NRG Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a NRG Furniture Expert? Answer questions, earn points and help others
