Question about Moen 4621 Chateau 1 Handle Bathroom Faucet W/drain Assy
Stopper does not close tightly feels loose and wobbly. newly installed.
How to install stoppers and side frame posts into the side frame bottom rail for twin wooden daybed model WM6394W
"Push down firmly" can mean judicious application of a hammer and wood block to get engagement.
May 19, 2016 | Furniture
Delta faucet will not hold water
The linkage to the drain stopper has to be adjusted so that the stopper seats when the rod is raised. If the stopper lifts out of the drain, it may be necessary to remove the lifter rod and insert it through the holes in the bottom of the stopper then reinstall. After this, pulling up on the faucet rod will force the stopper to seat rather than drop by gravity. The tradeoff is that you will not be able to remove the stopper without disassembly of the connection
Feb 18, 2013 | Plumbing
Clicking noise under gas pedal constant while running 94 silverado 1500 4x4
Hi, if you feel the click in the gas pedal it is the throttle cable not seated in the pully that opens the TB. The stopper will work itself loose if the cable is old or if you tamper with the TB pully. (i.e. reving engine by hand at TB under the hood.) Check cable at TB and be sure to pull it tight so the lead stopper on the cable is secure and seated. Not seated will cause the cable to wander in the pully. If the throttle feels sticky or clicks clean the TB with some gumout.
Jul 25, 2011 | 1994 Chevrolet C1500
Missing rear axle. is there a way to replace? the company won't.
I had the same problem. I bought this scooter for my daughter at a flea market and the rear axle was gone, someone had tried to fix it with a bolt, but it was very unstable. Here is what I did and it has seemed to work well. This will cost you less that 10.00 at your nearest home improvement store.
You will need
1x - 5/16 x 8 hex bolt 1x - 5/16 nut 4x - 5/16 x 1 1/4 flat washers 2x - 1 1/4 hard rubber stoppers 1x - 3/8 drill bit & drill 1x - gorilla glue or lock tight
Ok... before we start let me tell you what all this is for and how it works. The way I assembled this was, hex bolt, 1 washer, wheel for scooter, 1 washer, 1 rubber stopper (Insert this into the metal tube on the back of the scooter, so that on the other side you will just have a bolt sticking thru) now, 1x rubber stopper, 1x washer, other scooter wheel, 1x washer, hex nut.
The rubber stoppers are the hardest part and the reason for them is to keep the bolt going thru the middle of the axle tube. This will help to eliminate the scooter from wobbling.
Now, if you have read this far here is how we did it in order.
1. Take both rubber stoppers and trim them with a kitchen knife so that they will fit into the metal tube on the back of the scooter securely. (do not push them all the way in yet)
2. Drill a hole thru the middle of both trimmed rubber stoppers with the drill and bit
3. Take your hex bolt and slide a washer on
4. Slide your 1st wheel on
5. Slide on a 2nd washer
6. push on the trimmed rubber stopper to where it meets the washer. (The wheel should be able to still spin pretty freely, If you think it is to tight just pull the rubber stopper up a bit)
7. Take this assembly and push it into one side of the metal tube on the back of the scooter (you want the rubber stopper to be and flush with the edge of the metal tube and you can)
8. Your hex bolt will be stick out of the other end of the tube, slide on the last rubber stopper try and work it into the tube as best you can.
9. slide on 3rd washer
10. Slide on last wheel
*At this point I put the scooter on its side and pushed down on the wheel to force the stopper into the tube
11. slide on 4th washer
12. screw on nut
*Now I found that if you put the nut on to tight the wheels would not turn, but if you left it loose it would fall off.
13. To fix the above issue we put some gorilla glue on the bolt threads and screwed the nut on, we would spin the back wheels until we were happy with the amount of tension on the wheel. We then put some more glue on the top of the nut to help hold it in place.
14. Let the glue dry
Thats how I fixed my daughters scooter. I am in NO WAY a professional or expert at this stuff. Just a dad trying to make his baby happy. Hope this works for you!
Jan 26, 2011 | Bravo Dora the Explorer 3 Wheel Scooter
I discovered i was driving for several days with 2 missing lug nuts, a 3rd totally loose and the remaining 2 not very tight
The tire must have been worked on recently. With aluminum rims, it's not common, but not unheard of for the lug nuts to work themselves loose after servicing. It is recommended to re-torque the nuts 50-75 miles after service. Go ahead replace and tighten the missing or loose ones, and then in a day or so; after having put on the recommend miles, re-tighten them to insure their tightness.
Unless you feel a wobble or anything else in the suspension that could work a lug nut loose, you really should not have anything to worry about this aside from re-torquing the nuts.
Mar 24, 2010 | 1999 Volkswagen Passat
Have 2002 ford explorer,right rear wheel feels loose. checked lugs, all tight, pulled wheel and rotor is wobbly, losse. what's the cause?
You need a wheel bearing....don't drive it. Tow it to a dealer.! Ford wheel bearings are cheaper than aftermarket.
250-300 dollar fix.
Dec 31, 2009 | 2002 Ford Explorer
My washing machine feels level(doesn't wobble) but
I fastened my wife's washer to the wall with heavy wire inserted into 4 pieces of rubber attached to the wall and the wash machine. Rubber stoppers about one inch in diameter are held in place on the back of the washer about four inches below the top with copper pipe fasteners used to attach pipe to wood. These are on the back near each side and the ones on the wall are in matching locations. I used a 4" wide board on the wall so the screws could go into the studs and the stoppers could go where they were needed without concern about studs. The two pieces of heavy wire (not easily bent by hand) is bent into a U shape with a flat bottom and short legs. The width of the U depends on how far your machine is from the wall.The wire legs 2 - 4" long are then inserted down into the rubber with the bottom of the U upwards. Wherever you drill to attach the stoppers on the machine be sure to avoid any wires or mechanical components and I attached them near the top for ease of removal for maintenance-- which should be seldom. This solution has held my machine in place quietly for the last seven + years.
Jun 26, 2009 | Maytag Washing Machines
My press-to-close, press-to-open bathtub stopper needs to be replaced. How is it removed? Does it unscrew or is it pulled up? I have a three sided shower stall bathtub combination manufacturer unknown.
It is threaded in.
Most times they are installed hand tight and can be removed by grasping and turning counter-clockwise.
Channel locking pliers may be used to remove the existing stopper, it will be discarded anyway. The new unit only needs to be hand tight.
Good luck
Aduz
Mar 15, 2009 | Home
Slicing blade wobbles.
you can try to add a washer and if that doesnt work just go to a ardware store and get a shorter screw as well as some thread lock
Jan 21, 2009 | Food Processors
Moen 4621 Chateau 1 Handle Bathroom Faucet W/drain Assy Logo
18 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
