Question about HP® LaserJet M5035 MFP Laser Printer/Copier/Scanner/Fax/Digital Sending - Same Day
Please help with the error code
Error 60.06 tray 6 lifting error
How do i rectify code 0208 in bizhub 350?
Hi
I have managed to find some information about your problems. The error 0208 I couldn't find, but C0208 refers to the paper lift tray 4. Neither could I find C0200, but all the C020x errors relate to Elevator failure (or paper lift tray). If you go here:
Error Codes Konica Minolta bizhub 350 Code C0208
then you can view the results for the C0208 error and by using the right hand drop down menu, any other error code. You can also download a Service Manual from this site.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 28, 2014 | Konica Minolta bizhub Office Equipment &...
What is error code 60.02
60.2 is a lifter motor error, this is the motor that lifts the paper into position when you push tray 2 in. They do fail. Restart the printer and watch the paper level on the front of the tray to see if it moves at all. Also listen for any chattering noise is it does lift. Sometimes if the metal panel in the tray that lifts is not moving smoothly this error can occur. Pull the tray out and on the right hand side you will see a geared piece of plastic, rotate it to see if the tray lifts when you do. If not the tray might be the problem not the motor.
Sep 16, 2014 | HP LaserJet 4250n Printer
Error code U6-02
You have a large capacity double tray, the code is for the lift up motor in the right hand tray (that lifts the paper stack to the rollers) pull out the tray and see if there is paper wadded between the tray and the back wall of the machine blocking the motor boss from meshing with the tray.
Clear the motor error code with SIM 15 in the service area of the machine (from copy mode, # * C * to access)
If the code comes back your lift motor is worn out and needs to be replaced
Apr 20, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
I got a error code C-0204 and I`ve checked the tray 2 and is everything ok, but i still receiving this message and i cannot print. Please any help?
C0204 as I see you already know is a tray 2 elevator failure. Meaning the machine does not see tray 2 lifting up the paper. This is usually caused by improper paper loading, elevator sensor failure or lift motor failure. You can still use the copier/printer if you leave tray 2 open and inch or 2. Just use the other trays until repairs can be made.
Good Luck and Thank You for using Fixya.
Sep 25, 2010 | Konica Minolta bizhub C250 All-In-One...
A paper jam was not cleared in a timely manner, now the machine will only display "Error Code C0202, Call Technician" It is Saturday and I can not get a hold of anyone at our support center. How can I...
C0202= tray 1 elevator failure.
Open tray 1, check and make sure paper is loaded correctly.
With tray open, open and close front door. This will reset error code. With tray 1 open look to see if paper is stuck behind tray in back of machine, if so remove it ( this will block the lift motor for the tray).
Close tray 1, if you hear a popping noise the lift motor is damaged and will have to be replaced. Until it is replaced operate machine with tray 1 out to prevent error code.
Sep 18, 2010 | Konica Minolta Bizhub 362 Copier
I have a WorkCentre 5225 and it is telling me that I have an error (code #071-210) what is this error?
That error specifies a Tray 1 lift failure.
You probably can hear the motor lift 127K38171 when you re-insert the tray, so maybe the lift motor is bad or maybe a sensor
930W00113 is falsely accusing our motor.
Whit
Item, Inc
Aug 13, 2010 | Xerox Workcentre 5225 / Copier, With...
Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Sep 25, 2008 | Ricoh Aficio 450 Copier
DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Apr 23, 2008 | Panasonic Workio DP-1820E Copier
HP® LaserJet M5035 MFP Laser Printer/Copier/Scanner/Fax/Digital Sending - Same Day  Logo
49 people viewed this question
Seeker5211
Seeker5211
