Question about Roland Digital Piano FP4 Black With Stand 4139
Roland piano keys not working suddenly
Hi, all of a sudden my daughter's Roland hp101 digital piano keys have stopped working. The power light remains on but the tone and reverb lights flicker on and off intermittently. It seems that there is a loose connection somewhere as every now and then a key does produce a sound if it is held down. Any help would be much appreciated as my daughter is desperate to get her piano back. Thanks in advance
  • 5603 Answers
SOURCE: a couple of keys don't make a sound ? one never,
The contacts of most of these use a conductive rubber pill that is pressed against circuit traces with a hard black conductive coating.
These probably need cleaning. One has to disassemble the key switch area and clean both the silicone rubber "pills" and the traces where they contact. Carefully use 91 or 99% isoprophyl alcohol and a Q-Tip to clean these. The black pills are under silicone rubber dome things..
While you have it apart clean ALL of the contacts! You may find a lot of screws to remove. Use a little segmented plastic tray to keep the screws in order and OBSERVE the lengths of each... sometimes they vary and you want to get the correct ones back in the same places.
Posted on Jul 29, 2009
  • 5603 Answers
SOURCE: I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Posted on Oct 06, 2009
  • 5603 Answers
SOURCE: My Roland Rd-500 has no sound....the factory demo
You either did not get the ribbon cable seated OR got it upside down.
If this cable is the flat ribbon with exposed solder plated points of contact, OFTEN those connectors have a latch to release by GENTLY moving tabs on eaither side in the direction of pulling the cable out. This lock MUST be moved out slightly to allow the cable to seat properly. The solder plated contacts will be FULLY into the connector when seated properly.
These cables ALSO can be inserted backwards and NO connection will be made.
Posted on Feb 14, 2010
  • 74 Answers
SOURCE: roland hp550g digital piano has a couple of dropped keys
Power off the unit. Disconnect all cables that plug into the speaker base if you have one - It may be wise to document the individual wires to make their reinstallation easier. Remove the unit from the speaker stand and lay it on the floor on something like an old towel - you may get some dark colored grease on the rug. Remove the screws only for the bottom rear, not the front - you don't need to remove them. Do this by gently turning the unit upside down. Only remove the screws from the sides/rear bottom, and note which screw types you removed from where. Once all bottom rear screws are removed gently return the unit right side up. now pivot the top rear cover - the sides of the cover are attached to the rear - pivot it toward the back. No need to remove the ribbon cables - just let the top lay there or prop it up with something if the ribbon cables don't have enough slack for the top cover to lay flat on its back. You should now be looking at all of the keys uncovered. notice the rear of each key is where it hinges. You'll notice the grease at the hinge point. The keys are thin plastic so you must take care not to damage them. The way to remove a key is to spread the ears at the hinge point of the key you want to remove. I use a screwdriver sharpened to a point, but a large pair of needle nose pliers work good too. You insert the tapered point of the tool between the ears gently to spread them far enough to just clear the pins. Once they are spread wide enough you'll feel them disengage. Each key also has two hooks located side by side towards the front of the key on the bottom side - they are not visable until the hinge is released, but you must realise they are there or you'll either snap the key back onto the hinge or not be able to pull the key out once you've got it off the hinge. Pivot the key towards you to remove it. What you now have in your hand is not the defective part. You have the top that is touched when playing the keyboard. The defective part is still setting in the mechanism. What's actually happened is the keys are made of very thin plastic where they are glued around the weight and this plastic breaks leaving the weighted end down there somewhere. Examine where the key top came from and how it works. The key top is the part you took off of the hinge. You can see how the keys on each side work and you'll also see what is missing from the mechanism for the key you're working on. To make things easier I always remove one additional key top on each side of a key that I repair to make access easier. Just place the other keys you remove right behind the key area in the order you took them off so it'll be obvious how they go back on. Now the broken weighted mechanism you can lift right out. Actually you can lift it out easier with the weighted end broken off, but once you glue it back together you can still get it in there without to much trouble. You only need to remove the damaged weighted mechanism for the key you're repairing. I remove the key tops on each side of the damaged key for visability only. Take your pair of needle nose pliers and pick out the broken end. Now fit it onto the end of the weighted mechanism in preparation for glueing - just so you can see how it's going to go on there. I use a high quality modeling super glue. Before I came across this glue I used JB Weld, but it takes a few hours to dry. The high quality super glue allows you to put everything back together immediately. Installation is reverse of removal: Snake the weighted mechanism back in once you've repaired it - you can always examine those on each side if you get confused. Hook the key top front first then smoothly snap in place the hinge ears over the pins. Make sure to check the movement of the repaired key, and check also to see if anymore keys are setting lower as they may be in process of breaking off. Once all keys are repaired, carefull lower the top rear cover onto the key assembly. While holding the cover onto the key assembly/base, gently turn the unit over onto its back and reinstall the screws. Should be all washer headed screws - do not over tighten. Check the keys again. Set the keyboard onto its base (if it came with one) and you're done. A little practice and it'll take you less than a half hour to fix the key and get it back together
Posted on Sep 23, 2010
  • 5603 Answers
SOURCE: Hi, I am undecided about
I have two Yamaha's and I will say they are maintainable. Almost ALL the weighted piano key models use a keyboard made by one company as I understand it. I can easily get service manuals for the Yamaha, not quite as easy for the Roland... same goes for repair parts. Your decision... listen to each and decide. Hint: Use a set of headphones to do the compparision rather than internal speakers as the orientation in a music store can drastically change the sound.
Posted on May 01, 2011
Testimonial: "Great, thanks..I know that Yamaha fidelity and care is better."
I have a Casio digital piano and some keys stopped working after my daughter finished "cleaning" the piano. I'm thinking maybe a fuse needs to be replaced?? Some keys plays and some do not. Any
Old reply so hopefully it's fixed. Dust or hair can get through the gaps and land on or near the contacts of the electronic key sensors. To be on the safe side (rather than doing a diy) take it in to the technicians. They'll have it fixed in a jiffy
Feb 25, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
Sustain pedal does not work
Yamaha FC4 and FC5 sustain pedals are normally closed, sorry Fred. Roland is opposite. I suspect the P120 just needs to be reinitialized. Hold down top white key (C) while turning on power. Wait 3 seconds and then release white key. Should now be reset to factory spec. Always plug the pedal in before you turn it on. If it still doesn't work check it with a meter.
Mar 17, 2012 | Yamaha CP300 Stage Digital Piano...
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Problem with Yamaha YDP223 Digital Piano - Damper Pedal . The damper pedal on the piano suddenly stopped working (it was working before), but the two other pedals are still working fine. What may be the...
First thing is to check the connector is fully seated... sometimes most of the contacts make but one might not. Beyond that, contacts in the pedal are next suspect.
May 20, 2011 | Yamaha YDP223 Digital Piano
Hi, I am undecided about which digital piano to buy: Yamaha Arius 141 or Roland F110? help appreciated, thanks, karol.
May 01, 2011 | Roland F110 Compact Digital Piano 4867
Hi where can i get a service manual for an fp-8 roland digital piano?
Here's a link to the Owner's Manual
for a service manual, you're probably going to have to contact Roland directly, since they don't even list the fp-8 on their website. Service manuals for their other products only run about five bucks for a hard copy, i believe. I'm sure you can get to the right place through here: http://www.rolandus.com/corporate/contact_us/
Mar 19, 2011 | Roland Digital Piano FP4 Black With Stand...
Switch on e50 and sustain pedal not holding notes
I assume you are plugging this into a ROLAND brand product as the Roland sustain uses a normally CLOSED contact while MOST other brands use NORMALLY OPEN contacts.
The Roland synths now monitor the pedal as the power is turned on and supposedly decides which contact type is used.
Remember that for MANY voices, such as piano, notes are held longer BUT they do not continue indefinitely just like the sustain on a real piano works. On a real piano the dampers are lifted, but the strings eventually stop ringing due to the losses of energy in the strings.
Some voices will be held,such as organ tones.
I don't have enough information from your post regarding what voice you are having trouble with.
Mar 13, 2011 | Roland Dp-10 Damper Pedal-new
I have a Roland HP 101 digital piano however certain dont sound
White spirit is NOT what you should use. Mineral spirit leaves a residue film.
Use 99% isoprophyl alcohol.
ALSO inspect the contactboard for cracks by candeling with bright light behind it.
Oct 31, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Oct 05, 2009 | Roland Music
It's a Roland HP-7e digital piano about three years old.
You may need to clean the contacts which are usually conductive rubber. I explained stuff for another Roland problem with two keys that were intermittent. I have an EP-7 that I had to do the cleaning of the key contacts. Use 91 or 99 % Isoprophyl alcohol to clean BOTH the conductive "pill" (Black under silicone rubber domes) AND the traces on the board where they press. Clean gently as the traces have a hard black coating.
Jul 26, 2009 | Roland Music
Roland Digital Piano FP4 Black With Stand 4139 Logo
44 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
