Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
How do I rest my 2 ways radio - Motorola Talkabout T5720 (7 Channels) 2-Way Radio
  • 1,141 Answers
In order to rest it all you have to do is click the ptt button twice
Posted on Aug 07, 2007
4 radio communication
Pls swotch off qt & keep the same channel also keep all privacy codes to 0 , try ur set it will get connected to rest 3 , do not forget to keep privacy code 0
Jun 05, 2013 | Motorola Talkabout T5500 (7 Channels)...
T4500 with corroded battery contact- How do we clean / fix issue?
A fingernail file, the cardboard/sandpaper kind is the best method. Don't use any solvents. Once you have the corrosion mostly cleaned away, use a pencil eraser to gently clean the rest.
Best regards.
Aug 20, 2011 | Motorola Talkabout T4500 (7 Channels)...
I setup my motorola cls1110 to the same frequency as my other 2-way radios. (Freq 6, Code 10). When I try to push to talk all I get is a beep, and it won't allow me to talk. What can I do to fix this...
A beep when pressing the PTT button could be a low or bad battery indicator. It takes more energy to transmit than to rest idly or receive. Try a known good battery in the radio and see if it corrects the problem.
If the battery is not the issue, then you may have a programming problem. Typically radios with a blank or unprogrammed channel will beep when placed on that channel. Try programming the radio to a different channel and see if the beep still occurs. If the beep occurs on many program settings you may have a deeper issue.
Best regards.
Feb 15, 2011 | Motorola CLS 1110 (1 Channel) 2-Way Radio
It radio was given my store from another branch that was closing. And it has a lock on it. I need to remove the lock so I can change the frequency to match the rest of the radios at my store.
Unless you want to go to the expense of buying a programming cable and the software, take it to a dealer/shop and have them program it. It's illegal for you to program a commercial radio.
Jan 17, 2011 | Kenwood Protalk XLS TK-3130 (2 Channels)...
How do I reset my KENWOOD TK-3170-K 4 to original settings?? Thank you!!
- Power the radio OFF
- Power the radio ON
- Push and hold The UP arrow, DOWN arrow, and MON keys and power the set ON
- Release the keys when the message rESt (reset) appears on the display.
Need the manual? You can download and print it, at no cost, here:
Bill B.
Nov 22, 2010 | Kenwood Protalk XLS TK-3130 (2 Channels)...
How do I open up case to put antenna cover back on?
Open the battery cover by pulling down. Undo 2 T8 screws holding the top cover on. if you are using the belt clip it's a bit of a pain to remove - a screwdriver in the top pulling up may work - I ended up getting it half way out, then hacksawing off the rest. Then the back cover should unclip. Good luck, inside it's a pretty nice well built radio, except the antenna plastic is a bit weak, and it uses batteries a bit fast.
Aug 11, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Can Motorola TA200/T5622 work with newer T5000?
A 22 channel transceiver is an American system call FRS/GMRS radios which are actually illegal in the UK and rest of europe. They use different frequencies completely and will not work together on you other PMR radios.
Mar 15, 2009 | Motorola Talkabout T5720 (7 Channels)...
Comunicating between different models, can it be done?
sometime your program is wrong... so plz go this website and u can get soft the prob :)
this website have sofware :) so nice man!
Jun 13, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
41 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
