SAMSUNG SCX-5637FR INSTALLING DOCUMENT FEEDER FOR SCANNING
Mix-it-up
  • 832 Answers
SOURCE: lines showing up on document after scanned
Do you have lines, too when scanning a document?
In this case the scanner glas needs cleaning. Use a soft cloth and some glass cleaning solution and wipe the scanner glass. The lines should disappear.
Posted on Nov 12, 2007
maverick24
  • 56 Answers
SOURCE: Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Posted on Dec 03, 2007
SOURCE: HP LaserJet 2840 Scanner problem
Yes, but I don't see any actual paper jams. I have a Vista O/S and I've been reading that that might be the problem; the 2840 scanner driver is not compatible with the Vista O/S and HP hasn't produced a solution yet. I appreciate your efforts, thanks.
Posted on Feb 10, 2008
flopez
  • 161 Answers
SOURCE: Touble scanning more that one page as a document
If you are scanning using the Scan to PC button, the unit will scan as you described. In order to scan multiple pages into one document, you need to go go through the Smarthru software, or whatever scanning software your unit includes. Since your unit is manufactured by Xerox, you can go to www.samsung.com and download the SmartThru software of your choice for free.
Posted on Sep 29, 2008
  • 5 Answers
SOURCE: Line through scanned document when using the document feeder only
try cleaning the glass scan bar on the unit with a clean soft cloth.
Posted on Feb 20, 2009
Thick black lines when scanning Samsung SCX-4824FN
The contact image scanner is faulty or the cable from the motherboard to the contact image scanner is faulty. I would bet it is the CIS as this scanner is used in many different machines (canon,lexmark,sagem) and it gives problems in all the machines. You can usually salvage a good one from an elcheapo lexmark inkjet multifunction.
Feb 11, 2013 | Samsung SCX-4824FN A4 Mono Laser Printer
Samsung scx-4521f ADF cover, what does it mean?
That refers to the Automatic Document Feeder cover. If this is an error message, there may be a problem with the ADF that needs to be corrected
Feb 06, 2013 | Samsung SCX 4521F All-In-One Laser Printer
Black pages
u ll need to do servicing get the support from samsung customer care or log the call fro same.
Jun 13, 2012 | Samsung SCX-6220 Multifunction Printer...
Sep 16, 2008 | Samsung SCX 4521F All-In-One Laser Printer
The scan failed because of a scanner hardware error. Feeder may be jammed. Please correct the error and scan again."
Yep. I also can't scan using the Samsung SCX-4200, which results in that error
''The scan failed because of a scanner hardware error. Feeder may be jammed. Please correct the error and scan again.''
Richard Betambeau,
Reading, UK
May 20, 2008 | Office Equipment & Supplies
Scanning / faxing problem
you will need to replace the adf assembly or the portion of adf roller which was dameged.
typically one should open th ecover and take out the jam inth direction of papermovement only
happy faxing
omnipresent
Oct 17, 2007 | Samsung SCX-4216F All-In-One Laser Printer
26 people viewed this question
k24674
jasbo
jasbo
