Question about Lenovo ThinkStation S20 (415712U) Server
Enter bios setup
Overclock menu / voltage menu / sli menu
  • 3,799 Answers
Press F2 or Delete on system start. This should get you into the BIOS. Or you could look at the screen and press the button it tells you to-to enter "Setup".
Posted on Apr 29, 2013
Bios setup
If you can get the BIOS to load default settings, that is the safest thing for reliability to do.
Apr 29, 2013 | Lenovo ThinkStation S20 (415712U) Server
Tip
How to tweak your computer
Step 1
Back up important files. This includes impotant datas stored on your computer
Step 2
Update the firmware of your computers BIOS. Also update or patch your OS to the lates update and even your hardware devices must be updated as well.
Step 3
Also before proceeding ,remember to get a BENCHMARK test program that will help you see the changes and also monitor the temp. of your processor after overclocking
Make sure that your BIOS is also set to shutdown once illegal voltage or temp. will be detected
Step 4
Ensure that the CPU FAN is clean and is still calibrated to the right rpm
Step 5
Power on your unit ,hit the hotkey to access setup.On the BIOS go to ADV. CHIPSET option.Then look for"clocks, "frequency/voltage control" or "voltage options." This will look unique on each brand of computer.You can overclock by modifying "CPU bus frequency" or "CPU FSB frequency." Increase this value slightly. In some cases, you will be able to increase your "CPU multiplier" through the BIOS.If your BIOS has none of these options,your motherboard is not capable of overclocking the processor.
Step 6
You can also try overclocking your MEMORY AND VIDEO speed. Some motherboards have this options on the BIOS as well
Step 7
You can consult your motherboards manual to know the operating voltage of your cpu or type in the model of the board on yahoo or google.
on Dec 19, 2009 | Computers & Internet
My win xp has a coprocessor error can you kindly tell how to fix it my problem includes a bus controller error
Hi
Assuming you have not tried to overclock your processor, it would seem as if this is a BIOS or Motherboard Chipset Driver conflict or corruption.
Try first to clear the BIOS.
To enter BIOS (check bottom of POST screen for the correct key to enter SETUP), when in SETUP, select correct key for Reset to Default Values, then press F10, then press enter.
If resetting BIOS does not fix the problem, reinstall the Motherboard Chipset Drivers and then restart the computer.
If you did try to overclock the computer, then enter the BIOS and reset BIOS to default values, then save changes and restart computer.
Hope this helps.
Aug 22, 2011 | Computers & Internet
ASUS P5N-E SLI motherboard gives 10-15 sec bleeps at 0135 each morning. This sudenly started to ocure 4 nights ago.
Motherboards have a "timed-wake-up" option.
You can enter BIOS SETUP, and configure the computer to wake-up at a specified time, e.g., 01:35, on specific days, e.g., "daily".
Restart your computer.
Enter BIOS SETUP
Set the computer's clock to 01:30.
Save the setting
Exit from BIOS SETUP.
Turn the computer off.
Wait 5 minutes, until the computer's clock advances from 01:30 to 01:35, and watch what happens.
Mar 17, 2011 | ASUS P5N-E SLI Motherboard
System failed due to cpu overclocking. Not setup for overclocking in the bios.
Reboot, and enter BIOS SETUP mode.
Choose "Load Default Settings".
This will "undo" any overclocking of your motherboard and of your CPU.
Sep 20, 2010 | ASUS P4P800-E Deluxe Motherboard
When i start the through error overclocking failed! please enter setup to re configure your system how to solve this problem
If you dont know how to reset your bios settings back to default, maybe you should not be overclocking.
Enter your bios (check google for the key you need if you dont know it)
click default settings
Jul 25, 2010 | Computers & Internet
BIOS voltage settings for ASUS M2N-SLI Deluxe 570 SLI chip set.
Hi glen909nwi,
Here's the configuration for that board. If your trying to overclock, you'll want to go with a higher setting.
CPUChiosei HT Voltace 11.20 VI
Allows you to set the pocessorhipset HyperTranspoit voltage.
Configuration options: [1 .20V] [1 .25VJ 11 .30V] [1 .35VJ [+1 .40V1 [+1 .45V] [+1 50V]
Chtoset Core Vo#aae f1.40V1
Allows you to set the dlipset core voltage.
Configuration options: [1 .40V1 [1 .50V] [1 .60V]
Ctitpset Slan&w Core Vo?taoe 11.40 VI
Allows you to set the diipset standby coe voltage.
Configuration options: [1 .40V] [1 .6OVJ
CIhVsef Fi-E Voitaae 11.50 VI
Allows you to set the dlipset PCI Express voltage.
Configuration options: [1 .50V1 [1 .55V1 [1 .60V] [1 .65V] [1 .70V1
CPU Vcore Offset Voltage fDisabdJ
Allows you to csable or set the processo vCore offset voltage.
Configuration options: [Disabled] [Offset lOO.OnIV]
ASUS M2N-SU Deluxe
Oct 21, 2009 | ASUS M2N-SLI Deluxe Motherboard
Overclocking past 2.7GHz with Q6600 GO step
Please check BIOS update from mainboard manufacturer website it there has a solution for overclocking and others. Else don't push your motherboard so hard, you might get extraneous problem.
May 28, 2008 | Foxconn N68S7AA-8EKRS2H nForce 680i SLI...
Problem restrart pc /NO AUTORESTART
It sounds like you're trying to overclock your CPU, and you have exceeded what the CPU is capable of, under the current conditions. When you start the computer, enter BIOS setup (e.g. press the DEL key), and adjust the CPU settings to default. If you're not sure how to do this, choose the "LOAD OPTIMAL SETTINGS" or "LOAD DEFAULT SETTINGS" option from the main BIOS menu. If you are not getting this error until after Windows has started, then there is software installed that is trying to overclock the CPU for you. Uninstall it. It may be a program provided by Asus, or may be a third-party program. It will probably have "tweak" or "overclock" in the name. Overclocking can achieve an increase in performance, but will void the warranty, and does reduce the lifespan of the parts, and tends to make Windows crash more often. It can cause immediate failure of the parts. It should only be done if you understand and accept the risks, and have decided the reward is worthwhile. For most users, it is not worth it.
Oct 01, 2007 | ASUS P5LD2-VM Motherboard
Lenovo ThinkStation S20 (415712U) Server Logo
352 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
