Question about Lenovo ThinkStation S20 (415712U) Server
Bios setup overclock menu / voltage menu
    Top Expert:
  • Lenovo Master
  • 23,200 Answers
If you can get the BIOS to load default settings, that is the safest thing for reliability to do.
Posted on Oct 25, 2013
2 Suggested Answers
  • 3799 Answers
SOURCE: enter bios setup
Press F2 or Delete on system start. This should get you into the BIOS. Or you could look at the screen and press the button it tells you to-to enter "Setup".
Posted on Apr 29, 2013
Enter bios setup
Apr 29, 2013 | Lenovo ThinkStation S20 (415712U) Server
Tip
How to tweak your computer
Step 1
Back up important files. This includes impotant datas stored on your computer
Step 2
Update the firmware of your computers BIOS. Also update or patch your OS to the lates update and even your hardware devices must be updated as well.
Step 3
Also before proceeding ,remember to get a BENCHMARK test program that will help you see the changes and also monitor the temp. of your processor after overclocking
Make sure that your BIOS is also set to shutdown once illegal voltage or temp. will be detected
Step 4
Ensure that the CPU FAN is clean and is still calibrated to the right rpm
Step 5
Power on your unit ,hit the hotkey to access setup.On the BIOS go to ADV. CHIPSET option.Then look for"clocks, "frequency/voltage control" or "voltage options." This will look unique on each brand of computer.You can overclock by modifying "CPU bus frequency" or "CPU FSB frequency." Increase this value slightly. In some cases, you will be able to increase your "CPU multiplier" through the BIOS.If your BIOS has none of these options,your motherboard is not capable of overclocking the processor.
Step 6
You can also try overclocking your MEMORY AND VIDEO speed. Some motherboards have this options on the BIOS as well
Step 7
You can consult your motherboards manual to know the operating voltage of your cpu or type in the model of the board on yahoo or google.
on Dec 19, 2009 | Computers & Internet
System failed due to cpu overclocking. Not setup for overclocking in the bios.
Reboot, and enter BIOS SETUP mode.
Choose "Load Default Settings".
This will "undo" any overclocking of your motherboard and of your CPU.
Sep 20, 2010 | ASUS P4P800-E Deluxe Motherboard
RS482-M754 Warning!! Now System is in safe mode. Please re-setting CPU frequency in CMOS setup.
Shut down and start up the computer. As it's coming up immediately start pressing whatever is your setup key...could be F2..Delete...F10...whatever it is it should tell you on the screen as it's coming up..if not..just start pressing all of them until you get into the BIOS menu...if you see the Windows symbol come up you missed it...shut down again and try again...once you get into the BIOS menu...find where it talks about resetting your BIOS to factory Defaults...Select that and then exit and save...you should be good to go now. Were you trying to overclock your computer?
ASpecialty4You.com
Dec 20, 2009 | EliteGroup RS482-M754 Motherboard
Changing FSB & Voltages
Hi there.
You can change the front side bus in the bios if the bios supports it, if it does be very careful not to overclock the processor to much as you can cause damage to the motherboard and blow the processor up, also bear in mind that cooling is very important when it comes to overclocking.
Good luck and thanks for using FixYa!!
May 13, 2009 | Gateway Tabor 3 (4000532) Motherboard
Overclocking a CPU Type Intel Pentium IIIE, 581 MHz
If you have an adjustment for the VCORE voltage in your bios, bring it up by one value, then try overclocking the CPU.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
Reviving the cpu
The boards I have seen were overclocked by changing the CPU speeds or the voltages going to the CPU. Change the setting back. When you get into the BIOS setup screen(A lot of them you get into by pressing the delete key when starting up) look for the "Default settings" After clicking on them,save the settings. Thsi wil bring you back to the  Safest board setting according to the board maker.
Feb 26, 2009 | Compaq Pentium III, 366 MHz (400138-001)...
OVERCLOCKING
The 800 MHz seems to be your system bus speed and not the CPU speed. They a related but no quite the same. Overclocking is usually defined as forcing something to operate at a higher speed than it was designed to. If you changed the 800 MHz to 1.6 GHz in your BIOS then yes it could be considered overclocking.
One thing I would like to mention is that when changing clock speeds in your BIOS, do it in small steps, if done in large steps it can cause system instability.
Oct 28, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Problem restrart pc /NO AUTORESTART
It sounds like you're trying to overclock your CPU, and you have exceeded what the CPU is capable of, under the current conditions. When you start the computer, enter BIOS setup (e.g. press the DEL key), and adjust the CPU settings to default. If you're not sure how to do this, choose the "LOAD OPTIMAL SETTINGS" or "LOAD DEFAULT SETTINGS" option from the main BIOS menu. If you are not getting this error until after Windows has started, then there is software installed that is trying to overclock the CPU for you. Uninstall it. It may be a program provided by Asus, or may be a third-party program. It will probably have "tweak" or "overclock" in the name. Overclocking can achieve an increase in performance, but will void the warranty, and does reduce the lifespan of the parts, and tends to make Windows crash more often. It can cause immediate failure of the parts. It should only be done if you understand and accept the risks, and have decided the reward is worthwhile. For most users, it is not worth it.
Oct 01, 2007 | ASUS P5LD2-VM Motherboard
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
Lenovo ThinkStation S20 (415712U) Server Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
