Question about Saws
Mitre saw gear problem
Gear that drives the blade damaged can I obtain replacement parts if so from where can I obtain parts UK only thanks
    Novelist:
  • 99 Answers
I would need to know what make the saw is. Most brands have a dealer locator on their websites. Alternatively contact your local power tool distributor or tool hire company and they might be able to get the part for you. If you are in or around S.E. London or Croydon visit either of our outlets. Maps etc on our website www.lakedalepowertools.com . When you contact your local dealer, remember to make a note of the make and model of your saw. If it is DeWalt there will sometimes be a type number aswell, and Bosch/Skill will have a ten digit identity code on the rating plate and that would be the best info to take (e.g. 1.604.321.742)
Posted on May 05, 2013
stug_57u
  • 99 Answers
SOURCE: dewalt 708 sliding compound mitre saw
Probably a worn bearing. The only other thing that I have seen cause this is a bent spindle. This would usually occour if the machine has had an impact or if the blade has been suddenly jammed against a nail or something in the work that has caused it to jam and/or jump up.
A good indicator for bearing wear is to see how much play is in the blade in an up/down and side to side movement (unplug saw, safety first).
To check spindle, remove blade and run machine without the flanges etc on. Rest a scredriver gently on the shaft as it spins and see if you notice any (uniform) vibration.
Posted on Nov 01, 2008
efs_perpends
  • 1996 Answers
SOURCE: I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Posted on Apr 10, 2009
brewerstool
  • 141 Answers
SOURCE: I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Posted on Oct 13, 2009
rsmith972278
  • 160 Answers
SOURCE: can't get the handle of a mastercraft compound mitre saw to open
Hi, If you look on the left side of the saw near where you see that it pivots to go up and down. You will see some type of knob that you can pull out...you will need to push down on the saw handle to allow this to happen.
Hope this helps, RSMITH972278 P.S. PLEASE RATE MY ASSISTANCE
Posted on Dec 29, 2009
Testimonial: "thanks, got it working."
  • 12 Answers
SOURCE: Mastercraft Maximum Compound Mitre Saw
Mastercraft's help line is 1-800-689-9928. However this saw is no longer in production and parts are available only until stock is depleted. It was supplied by an european company called WMH Tool Group that apparently doesn't supply CTC any longer.
Posted on Aug 31, 2010
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
I have a Performance Power Tools PP1100MS mitre saw and i need to replace the blade but its not obvious how to do it and i have no manual.
Hi, I too have a performance power mitre saw pp1100ms and need to replace the brushes. I have the parts but no diagram...any advice please ????
Nov 10, 2013 | Saws
Jcb mitre saw
try ringing jcb on 01889590312 and they will put you in touch with a distributor that has the part.
Jul 28, 2013 | Ryobi Saws
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I have a mastercraft mitre saw. The blade blocks midway when I am
The picture I could get only shows one side. From my experience, these guards operate using leverage, where a little motion results in a lot of movement to the guard. That means a little damage or wear in the linkage can make a big difference. A bushing may have shattered, or a pivot hole may be worn out. Reviews of this machine mention dust not going into the bag. Make sure dust is not jamming the guard works. Take care, having to move a guard while the blade is spinning is scary.
Mar 28, 2009 | Dewalt Mitre Saw Workstation
I need a parts Diagram for a MasterCraft 8.25'' Compound Mitre Saw
I have the manual and prts list , you can phone this number for parts, the parts depot is in Ottawa 613-724-7724. if you the diagram send email to frogman1962@hotmail.com and I will send it to you.
Mar 24, 2009 | Hand Tools
I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
Mar 15, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Saws Logo
43 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
