Clipper erro I am getting following error; error eut0016: Open of buffered output file 'KA.EXE' failed Fatal Error - Abort: Permission denied
SOURCE: permission denied error when access hidden folders
ابي الثيم بأي طريقه ما عرفت لي اسبوع ادوره ما جبته
Posted on Sep 20, 2008
  • 917 Answers
SOURCE: I get fix getfiletext.browseit.permission denied
Check you PC for viruses
Posted on Feb 16, 2011
SOURCE: error get file text. browse
Error get file text. browse it. permission...
Posted on Mar 24, 2011
shahidkap97
  • 392 Answers
SOURCE: Fatal error: Couldn't get device caps DirectX error message: D3DERR_NOTAVAILABLE File: \project\igi2\B\2\PC\pc_direct3d.c line: 2634
did you install direct x in your computer? if not then download it and get it installed and then try reinstalling the program
Posted on Apr 07, 2012
What is fatal error 762
Trying to test this plugin on XAMPP localhost test site. Nothing shows up so I looked for errors and found this: Warning: require_once(C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow): failed to open stream: Permission denied in C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow\blip.php on line 762 Fatal error: require_once(): Failed opening required 'C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow' (include_path='.;C:\Program Files (x86)\xampplite\php\PEAR') in C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow\blip.php on line 762 --------------- The code on line 762 is the require_once, but here's a few lines before // attempt to talk to WordPress $blog_header_path = preg_replace("/wp-content\/.*/", "wp-blog-header.php", getcwd()); if (file_exists($blog_header_path)) { require_once($blog_header_path); }
Feb 12, 2015 | Office Equipment & Supplies
Tip
STOP: c000021a {Fatal System Error}
This article is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact Technical Support.
When you use a server or a workstation that is running one of the operating systems that is listed in the "Applies to" section, you may receive the following error message: STOP: c000021a {Fatal System Error}
The Windows Logon Process system process terminated unexpectedly with a status of 0xc0000034 (0x00000000 0x0000000)
The system has been shutdown. Note The parameters in parentheses are specific to your computer configuration and may be different for each occurrence.
CAUSE:
The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Resolution will not fit here so kindly go to:
http://support.microsoft.com/default.aspx?scid=kb;en-us;156669
I hope it helped you. Rate for this information will greatly be appreciated. Thank you!
on Jan 20, 2011 | Computers & Internet
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
My computer retain this error and close application error code 3
I am also getting error code 3. I am able to transfer files using the exe. but running it from the scheduler/console I get:
permission denied
error code 3
error message from server permission denied.
why would I get that from the console and not from the ex
for more help visit CBR Tech Solutions
Apr 23, 2014 | Computers & Internet
Fatal error
Copy the file config.qvm and other .qvm files from C:/program files/eidos interactive/progect igi/pc to C:/program files/eidos interactive/progect igi/pc/common/ai
May 21, 2013 | Video Game Consoles & Games
Hp 1402 fatal error and MSI.scan
Hi Ihan,
You are facing terrible problem with that error message.. However we can try to fix it. There are few methods you can do..
Solution 1.
  1. Insert the product software CD into the CD-ROM drive on the computer.
  2. Right-click Start and then click Explore . Windows Explorer opens.
  3. Locate and select the CD-ROM drive that contains the product software CD.
  4. Locate and double-click the Setup and then the Scan folders to open them.
  5. Double-click Data1.cab or Scan.cab to open the contents of that file.
Extract, rename, and save the filesLocate the following files, right-click them, select Extract , and save them to the Windows Desktop. Leave Windows Explorer open after extracting the files.
  • F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the Desktop, right-click it and rename it to TWUNK_16.EXE .
  • F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWUNK_32.EXE .
  • F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN.DLL .
  • F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN_32.DLL .
Then you have to copy these files to C:\windows\system32 folder ( this means overwrite the files ) and try to install the software. it should work.
for better understanding check the link below.
MSI.SCAN Solution
Solution 2.
you need to remove all the HP Printer entry from Add/remove or Programs and features under Control panel.
Then download the latest software from HP website by clicking on the link below.
HP PSC 1402 Printer Drivers
Regards,
Suhail
Oct 19, 2011 | Office Equipment & Supplies
I've unplugged it, replugged it, and still get "service call 173:fatal error"
check mechanical error on your printer by sending it to the actual technician..
Sep 01, 2011 | OKI C5500n Printer
My screen appear you are a victim of software counterfeiting how to erase this or resolve it thank u
Start Windows Registry editor and delete the folder "WGALOGON" located in the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ Windows NT\CurrentVersion\WinlogonNotify. Delete all references in your registry to WgaTray.exe
Another alternative suggest that three files are installed Windows XP System Folder:
\WINDOWS\system32\WgaLogon.dll
\WINDOWS\system32\WgaTray.exe
\WINDOWS\system32\LegitCheckControl.dl...
The wgatray.exe process makes the check for genuine windows software. You can disable WGA by removing the execute bit on WgaLogon.dll. That way, winlogon can't call it as a notification package at boot, and since WgaLogon is responsible for running and maintaining WgaTray.exe, no more tray popups either.
To change the execute bit of WgaLogon.dll, first turn off Simple File Sharing. Now right click the file in Windows Explorer and open the Security Tab. Hit the Advanced button, uncheck the Inherit box at the bottom, hit the Copy button, then hit OK. Go through each listed user/group and remove the "Read & Execute" permission for that file, leaving the "Read" permission as-is.
Hit OK to apply the permission changes and close the file properties dialog. Restart the machine. You can now turn "Use simple file sharing" back on, if you want.
A third alternative posted on the internet suggest that users clear the content of file data.dat located in the following directory:
C:\Documents and Settings\All Users\Application Data\Windows Genuine Advantage\data
Save the data.dat empty file and change the attributes to "Read Only" - Restart you computer. Or start your PC in Safe Mode and delete the following files from Windows system32 folder - wgalogon.dll spmgs.dll wgatray.exe The WGA setup file is in C:\WINDOWS\SoftwareDistribution\ Download\6c4788c9549d437e76e1773a7639582...
If you don't use "Fast User Switching", you can disable the Windows XP Welcome Screen if you are logged in as an Administrator. This will remove the initial WGA Warning Screen:
1. Click on Start -> Control Panel ->User Accounts
2. Click on "Change the way users log on or off"
3. Uncheck "Use the Welcome Screen" - Choose Apply
4. Close the User Accounts window and the Control Panel
5. The next time you reboot your computer, the classic login prompt will be used
To enable Fast User Switching, you must also enable the Use the Welcome screen option. Also, Fast User Switching cannot be used when Offline Files are enabled.
Disable wgatray.exe - Some users are claiming that removing the WGATray.exe (or killing the WGATray.exe process) are working for them. Here's how to search for WGATray.exe file - Screenshot
None of these methods are guaranteed to work and people are just experimenting. Meanwhile Microsoft is not willing to relent to crackers this time and are planning to release an update of WGADiag2.exe utility in the next few days.
WGADiag2 will also fix the problem with registry key permissions may cause the installation of Windows Genuine Advantage Notifications KB905474 to fail from Windows Update:
Here's a manual fix provided by Microsoft. These permissions can be repaired using Registry Editor as follows:
1. Click Start, and then click Run
2. In the Open box, type regedit, and then click OK
3. Expand HKEY_CLASSES_ROOT
4. Locate the subkey HKEY_CLASSES_ROOT\LegitCheckControl.Legi...
5. Right-click the subkey and select Permissions....
6. Ensure that Administrators allowed Full Control permission
7. Repeat steps 3-6 for the subkey
HKEY_CLASSES_ROOT\LegitCheckControl.Le...
Microsoft has also published a kB article if the Windows Genuine Advantage (WGA) validation check process does not validate successfully on a Microsoft Windows XP-based computer, and you receive one or both of the following error messages:
Product Key Inaccessible 0x80080212
This problem occurs when you do not have the appropriate permissions for the Windows Genuine Advantage\Data folder. In the Permissions for Users section, make sure that Read & Execute, List Folder Contents and Read permissions are given. If the previous steps fail, start the computer in Safe Mode and rename the %allusersprofile%\Application Data\Windows Genuine Advantage directory.
May 20, 2011 | Computers & Internet
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
Jul 24, 2010 | Acer TravelMate 2480-2968 Notebook
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
