Question about Home
In what materials can you buy stovetop kettles?
    Problem Solver:
  • 52 Answers
You can find them in aluminum, stainless steel, glass, copper and cast iron.
Posted on Apr 29, 2013
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
Tip
How to clean out your stovetop kettle
I've been using the same kettle on my stove for about a year and I hadn't cleaned it even once until last week.
A while ago I started noticing these weird white chucks that would come out with the water but I just figured that it was because I get a lot of use of out my kettle.
It turns out that the white chunks are actually limescale.
I did some research on it and thankfully limescale is not harmful to ingest. However, it's pretty gross to look at and I certainly wouldn't want to serve a cup of tea to a guest that is filled with strange white flakes.
So I figured out how to clean my kettle with stuff I have at home.
All you need is some regular cooking vinegar to do the descaling for you.
There is no need to buy expensive chemicals that you wouldn't feel safe using on a cooking product anyway.
Start by rinsing out your kettle with warm water.
Then, fill half of it with water and the other half with vinegar.
Place it on your stove and let it come to a rolling boil.
Then, just leave it there over night.
When you wake up in the morning, dump out the water and vinegar solution.
Take a long scrubbing brush and scrub the inside of the kettle to remove whatever limescale is left.
If there is still some caked on, you can repeat the steps over again.
If your kettle is clear of the grime, simply rinse out a number of times with soap to get rid of the vinegar taste/smell.
Voila! Your stovetop kettle is clean and no more unidentified chunks in your tea!
on Jan 06, 2014 | Home
Can triggers be replaced?
Take it to a repair man, or mostly, just purchase another kettle...whe they start to break, better another new one, because tempering will lead to more frustration or worse, eletrocution.
Jun 14, 2014 | Alfay Designs Inc Remedy Metro 1.5-Quart...
Pot doesn't shut automaticly when starts boiling
I had this problem too, but once I made sure the lid was securely closed, it was able to build up enough pressure inside of the carafe that it flipped the switch to off. So I'd try making sure the lid is snapped closed, which takes a bit more pressure than you'd think.
Be careful about doing this while it's boiling though! Steams a b**ch
Apr 08, 2014 | Bella 13822 Tea Kettle, Electric
Is there a problem using coil burners for a glass stovetop kettle?
The problem with a coil burner is it does not heat the glass evenly so it can crack.
Apr 29, 2013 | Home
What is an electric kettle? Is it different than stovetop one?
An electric kettle uses electricty and not the stovetop. Once the water has boiled, the kettle stops heating the water and you hear a noise signaling that the water is ready. I use one every day becuase I find that it boils faster than using a stovetop.
Jan 16, 2013 | Home
The stovetop glass has cracked on my KESH307 Superba Electric Range. How do I replace this?
The price to replace is very high that is the problem with having a bunch of new age products there is no cheap way out ect ford motor part vs a Kia part f
Sep 25, 2012 | KitchenAid KESC307 Electric Kitchen Range
Melitta MEK17W Electric Kettle: The little filter that fits into the spout disinte...
Call 1-800-233-9054 and ask Salton/Toastmaster for part number 31036 for the MEK17W kettle. You may as well buy 2.
When this scale filter in the spout of a Melitta MEK17W or Toastmaster TEK17W (identical kettles) gets torn the kettle does not hold in enough steam to trigger the auto off switch. Same thing happens if you do not fully close the kettle lid. With a new and spare scale filter you will get way more life out of this inexpensive and handy kettle.
If you still have the old original filter, here is an inexpensive and permanent repair option using stainless mesh:
www.fixya.com/answer/answerpageslideview.aspx?thid=10641367&ctg=163&lst=1#answer-section
May 06, 2010 | Salton Melitta MEK17W Electric Kettle
Home Logo
906 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
