Question about Hotpoint Dryers
Hoptoint CDT40G condenser tumble dryer pump running no heat or movement
Hi, My tumble dryer turns on but when it starts the only thing that runs is the water pump. I have opened the pump and cleaned out all lint etc, the float is not stuck and is free to move. The channel from condenser to the pump is now clear and free of lint and the area beyond the condenser is dry and clean. The empty water light comes on when the machine starts but it then moves to the programme when I press start. Any help would be great? Thanks Jamie
  • 108 Answers
Hi i have a ctd40 mine wouldent go a few years ago on the heater i had three stats on one of them there is a tiny hole i pushed a sewing needle in hole it reset the stat you can see if you look at bottom of stat it might be concave so pushing it out set it again dryer then worked pull plug first
Posted on Feb 14, 2014
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
SOURCE: hotpoint CTD00 Tumble Drier: No water in draw, 3x as long to dry
sounds like pump has gone
Posted on Aug 31, 2009
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
apart4u
  • 213 Answers
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
apart4u
  • 213 Answers
SOURCE: dryer not heating
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
My Amana dryer LE4427W does not turn on or make any sound or movement what-do-ever. First it was discovered that it was just tumbling with no heat and then the next time we tried to turn it on, it did...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Amana Dryers
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Dryer not tumbling heat but no tumble
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Apr 19, 2010 | Bosch Classixx WVF 240S Front Load Washer...
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
Tumble dryer
Can be a few things. Start by resetting your circuit breaker. The dryer motor can run with partial power but the heating element cannot. Make sure your not set to a no heat setting. After those checks you have to get into the mchine to check your heating element and thermostats.
Apr 12, 2008 | Whirlpool LER5636P Electric Dryer
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Dryers Logo
88 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
